Automatic Gearbox breakdown...Help!!
They told me two interesting things:
1) One of the reasons because the transmision broke is that mud entered into the "ventilation lines" of the transmision. I don't have a clue of what that lines are, but that's what they said and the transmision expert said it's very common in four wheel drive cars to break down the transmision when crossing rivers or getting into deep mud because it enters in this tubes. Solution: take them up or even connect them to the snorkel (it sound very weird to me, but they said It can be done). Cost: about 60 €.
2) The non-overdrive transmision, previous 93 (at least in HDJ), is got a big weakness: the radiator is shared with the engine and it doesn't cool the transmision as it should. Solution: to fit in an independient oil radiator for the transmsision similar to the one with overdrive. Cost: about 150 €.
Those are both excellent suggestions; your mechanic knows what he's talking about.
Here's about the only person in the world (seriously) that I'd trust to rebuild an A440F transmission (which I believe is the model you have):
http://www.automatictransmission.com.au/
Owners' name is Rodney Hudson-Davies; he ships to the US and possibly to where you're at. If I were you I'd get in touch with him as soon as possible.
Other than that, if you really can't afford a new one, I'd seriously consider used rather than rebuilt, since a locally rebuilt one is just going to be a crap shoot anyway.
Good luck,
Curtis
Other than that, if you really can't afford a new one, I'd seriously consider used rather than rebuilt, since a locally rebuilt one is just going to be a **** shoot anyway.
Good luck,
Curtis
I second what Curtis said. Talk to Rodney. I'm going to use him when it's my time for a rebuild.
Do you suggest to send the transmision to Australia to be rebuilt and ship it back here?. I think the cost of the shipping two ways would be crazy!!
How much would that cost from the US?, to ship a transmision from the UK to Spain, (which is quite a short distance), cost more that 300 € (400 $), per way. I can't imagine the price to Australia, with twenty times the distance.
Between the other two options, what are the disadvantages of getting it rebuilt in a local specialist?, I know a guy that rebuild his Mercedes transmision six months ago in the same place and, at the moment, he is satisfied.
I know the best choice is to get a good used one, but, ¿how do I know if it's already damaged and near to break down?, they have no warranty.
ROdney does special work on the 80's transmissions. Anyone who's had it done raves about the improvement... With the local guy you will get stock functionality if you are lucky. With Rodney you get more... Call him up and read some info on their website..
He sends you one that he's already rebuilt, and then you send your old one back to him (in the same crate) so he can rebuilt it for someone else.
He ships all over the world. It may or may not turn out to be a reasonable option for you, but it'd be stupid not to find out.
Curtis
Edit: Actually, I'm not sure he even needs your old one; I can't remember for sure...
More info, cut and pasted from the 3FE Yahoo Group:
Re: A440F tranny
Hi it's Rodney here from Wholesale Automatics.
We don't have any prices on the web site because the prices change
depending on what options you want when ordering your transmission.
Plus we need to know where you are so we can quote freight to your
closest major city.
Here is a full list of options, there are 2 complete list of options
depending if you are starting out with a standard rebuild or an
Extreme rebuild. Make your own package up.
Standard Complete A440F Rebuild $2070 Aus = Approx $1449 U.S.
Extreme Recalibrated Valve Body With 3rd and 4th Gear Lock-Up $795
Aus = Approx $556 U.S.
http://www.automatictransmission.com.au/release.asp?NewsId=11360
Complete Temp Gauge Kit $225 Aus = Approx $157 U.S.
http://www.automatictransmission.com.au/release.asp?NewsId=12031
Large Oil Cooler $190 Aus = $133 U.S. But you can get cheaper units
in the U.S. that are just as good.
http://www.automatictransmission.com.au/release.asp?NewsId=12319
Newly released Billet Extreme Heavy Duty Torque Convertor $990 Aus =
Approx $693 U.S.
Second Option is An Extreme A440F Rebuild $3270 Aus = Approx $2289
U.S. Already comes with the Extreme Valve Body Fitted. You can
simply add the temp gauge kit, Cooler and Billet Toque Convertor as
listed above. Below is the A442F link but it's almost the same
trans.
http://www.automatictransmission.com.au/extreme_a442f.asp
In short the Extreme Transmission already fitted with the Extreme
Valve Body with the Extreme Billet Torque Convertor is the best of
the best. It works so well that we fit the Chevy 6.5 Turbo Diesel
Engines in front of this unit in the 60,61,62 & Early 80 Series not
to mention any other V8 Conversion or heavy duty use you might
have.
Now you know why we don't list the prices on the web site as it can
get a little confusing. The U.S. dollar is doing very well against
the Australian Dollar at the moment so these U.S. prices are the
cheapest I've seen in 2 years.
These is a freight cost that I can only quote once I know where you
are. You must return your old transmission packed in the same
plastic packing crate back to Pomona C.A at your own cost where we
will return it back to Australia FREE of charge. We load our
containers from Pomona C.A.
Hope this helps.
Kind Regards
Rodney
Wholesale Automatic Transmissions
Factory 1/58 Barry St
Bayswater
Victoria
Australia 3153
Phone: 011-613-97628004 Direct number from the United States and
Canada
--- In 3FE@yahoogroups.com, Adam Churnside <chur8147@...> wrote:
> Hey Rodney,
> What does an extreme tranny from you run. I looked at your
website
> and either I suck at searching or couldnt find the price of
those. I
> have heard a lot about you and I think this might be the option
that I
> might go. I am going to try and perform your flush and see if
that
> solves anything. Thanks for your help
> ----- Original Message -----
> From: Rodney Hudson-Davies <rodtina@...>
> Date: Wednesday, March 29, 2006 3:49 pm
> Subject: [3FE] Re: A440F tranny
> To: 3FE@yahoogroups.com
Dude drop a mail to jose@spiritt4x4.com mate cruiserhead in Valencia Spain .. ( in spanish he's not an english man ) maybe he have suggestion for you coz are in the off road and cruiser wold for a long time ( owned a HDJ-80 )
Did you already change the fluid of the tranny .. ?
I'm pretty sure that you can found qualified mechanics in Spain .. which one it's the key ..
I've seen Roney's page with the rebuilt of a heavy duty transmission and it looks superb. I sent him an email asking for the shipping prices to Spain.
Apart from that, I've found an spares house in England that sells me an used on with one month warranty for about 900 $. I don't know the state, but I think, if they give warranty, even such a short one, It means they at least checked it and it's working.
What do you think?
Tapage, I'll contact jose, maybe he knows someone here, but I can tell you there are not many automatic transmission specialist in Spain (90 % of the car have manual transmissions). I changed the fluid and it came out with pieces of metal in it (bad signal).
At last, as I don't have the money to get Roney's transmission, I've ordered an used one, and I'll fit higher breathers and bigger radiator and see what happens. I wish I could get Roney's heavy duty transmission, but it's twice the price and I can't afford it.
I have a big problem now when ordering the transmission.
My one is Land Cruiser HDJ 81 1991 VX Limited, UK registered but originally Japanese and imported in 1998.
The one I'm taking the transmission from is a Land Cruiser HDJ 81 1991 VX, but this one is the genuine UK model.
When opening the Gearbox, on the driver's side: you can see:
Aifin Seiki (in both of them)
1D1427 (in mine) and a different code (I don't remember it) in the other one.
Are they the same gearbox?, what's that number?, do you think it's a part number or only a serial number that identifies each unit?
Thank you.
Nobody knows?, I have to make the order and I can't find a clue.
I even phoned some Toyota dealers and they can't give me an answer.
Does your 80 have the full time four wheel drive? As far as I know there were only 3 automatic transmissions in the 80. One is US specific (343f), the 440 which I think only came with the 3fe engine, and then the 442 which is what I would guess is the transmission that you have.
The real problem is those are the only transmissions that were available in the US for the 80 series, and knowledge of any sub variety of those will be limited.
Also are you sure it says "Aifin Seiki" and not Aisin something?
