Auto tranny question.
Firstly this cruiser is my first vehicle with an auto in about 10 years so forgive the ignorance.
When the truck is warming in high idle or the AC is on, the truck in drive but not moving (ie brake on) there is a vibration in the drivetrain that you can feel in the truck. This goes away when the truck is idling normally.
Anyone know why this would be?
Truck is a 95 80.
Seems to be normal.
Truck is a 95 80.
Assuming the tranny shifts OK/normally what you describe does not sound like the trainy; if it is a significant vibration, it could possibly be something touching the frame ie: normal engine vibrations being conducted into the frame or body. Could be from loose or worn motor mounts, bad exhaust system mounts, missing clamp that runs from the firewall bracket to the exhaust pipe, etc,etc
Or, it could be normal.
But then, I am not a mechanic, just have experienced most of these
symptoms myself in my 1996 FZJ-80. I had the motor mounts and
tranny mount replaced in mine; no improvement, but I now have new mounts:-)) Also, when it was under warranty, the dealer put in a new Harmonic Balancer; no improvement, but I got a new HB then too.
g
I was thinking maybe the idle is set too high? Could this do it? What is the ideal idle RPM?
What is your idle when warm and without the A/C on?
You understand it's supposed to be significantly higher when cold and/or with the A/C on, right?
Curtis
Yea, I think it is around 800 normal - 950 w/AC on. My current theory is that the idle is too high and it causes the tranny to want to engage.
I'll confirm the numbers tomorrow morn.
K so I checked the idle and warm with the tranny in park or neutral it is pretty well pegged at 600rpm. Turn on the AC and it jumps to around 900.
Sounds normal. Have you checked your exhaust mounts yet? I'm betting thats where the vibration is coming from.
Exhaust mounts are all fine. It doesn't feel like a rattle but the whole truck vibrates like the tranny is engaging too early. Maybe I'm just being silly. The PO said he noticed it after installing the OME medium lift but this doesn't seem to make sense as it only really happens when the truck is at a stop. The PO also put synthetic oil in the tranny a couple years ago, could it be an incorrect fluid?
Otherwise the tranny seems to shift perfectly.
It might be worth checking the gearbox mounting, between the gearbox and the cross member. Jack the box up slightly and see if the rubber has seperated from the metal. If it has you may get more vibrations in cirtain conditions than normal. Pretty easy to replace if so.
