auto locker Differnces
60K+ miles so far and going strong on my Aussie. Mostly on road driving so far; occasional wheeling. That's why I forget I have locker in the rear. Only time I remember is when I press the CDL switch; I get two lockers engaged by pressing one button :lol:; that within itself is a great advantage :). It's priceless.
x2 I love mine. I don't even know its there till I need it. Best mod to date!!
Have a lock right in my 80 and love it. It is there when you need it and almost none existant when just driving around.
I DD my rig as well.
Picked mine up for $200 and installed in and hour.
Now that is easy.
Either lock right or aussie you will be happy.
Just get one and put it in and forget about it, you will not regret it.
Here's another issue that could be a decision point for some considering whether to choose between a lunchbox locker and spending the extra money on an ARB. How do the lunchbox lockers perform on snow-packed or slickened roads?
I had a LSD in a Dana 44 and never had an issue with it, but didn't expect to. I can see where a lunchbox could present issues in the snow running on curves on the road. Won't it tend to "push" in trying to correct for what it sees as a slippage situation?
An ARB would not be an issue on snow-covered roads, because it would never be engaged. The diff would simply do what it always does.
For those of us in northern tier states or who do winter driving in the mountains, maybe the ability to selectively choose locking is a factor that is something worth the extra cost? Or am I making more of this issue than it actually is in practice? After experiencing the confident handling of the 80 with open diffs in snow on the highway at road speed, I'd hate to do something that will compromise that capability.
I ran a Detroit rear/TruTrac front in an AWD XJ, and it was incredible in winter conditions. I would to this day take that setup over the selectable 80 for winter use, because you are not confined to the selectable open/spool of factory or ARB lockers.
An auto locker is locked in normal configuration - it disengages to allow differentiation depending on torque load. With an auto transmission, this will generally happen seamlessly at speed, providing the traction advantage of no slip in forward motion but automatically allowing differentiation if needed around steeper curves (if you stay off heavy throttle).
I replaced an Auburn clutch driven limited slip with the Detroit in my old rig - the Auburn would lock up unpredictably and often cause rear wheel spin and slip up hills. All taken care of with the Detroit.
The point about an ARB never being engaged on snow covered roads is generally accurate - and that is the problem: it leaves you open, which is not ideal for winter traction. Lock it manually and you have a spool, also far from ideal.
Selectable lockers are probably the best overall combination of features, but they do have downsides, and an auto locker in the right kind of rig (like an 80) can be incredibly effective with the right driver.
As well as cost. I purchased my aussie used w/ low mileage on it for ~$175 vs 1.5K for arb or retrofitting an elec. oem.
That is not how they work.
Autolockers only lock both drive sides when a wheel is slipping. They don't care about the torque load unless it is enough to make a wheel slip. Otherwise, one side is driving and the other side that is rotating faster ratchets. They switch drive sides when you turn the opposite direction and when you go from drive to coast and this is what a lot of people interpret as "locking".
Now I'm confused. I thought with an Aussie locker, both wheels are always locked (powered) unless you are turning on a high traction surface and one wheel cant spin (lose traction)...then they unlock
no just the opposite. its open till the two wheels start spinning at differnt speeds than it locks up. Torque plays a factor as the more torque you apply the less ratcheting you get from the locker.
All that being said I don't notice it till I take a curve with my foot pegged to the floor then I feel the over stear.
False.
Taken from Aussie Locker's website:
"The “Aussie Locker” design is automatic in that there are no actions required by the driver to actuate the locking capability. The locker is always locked and unlocks in turns when the outside wheel overruns the speed of the inside wheel.
There are no cables, electrical wires, air lines, pneumatic or external connections of any kind required.
No.
The way they work is:
In forward (drive), one wheel can turn faster than the ring gear, but niether wheel can turn slower than the ring gear. The same thing happens in reverse (coast). Torque has absolutely nothing to do with it until there is enough torque to cause one wheel to slip, then both sides will lock and turn the same speed as the ring gear. It is pretty complicated operation for something that looks so simple.
The Aussie web site explanation is oversimplified. It depends on what you mean by "locked". Obviously, one wheel is always locked. If you mean both wheels locked this really only happens when one wheel is slipping because otherwise one wheel is always turning faster or slower than the other, even if only slightly.
"The locker is always locked and unlocks in turns when the outside wheel overruns the speed of the inside wheel."
1) The locker is always locked. The locker...is locked...always.
2) Number one above means that it is acting as a spool or welded diff. Whatever torque is being sent down that driveshaft is being distributed equally between the two wheels on that axle.
3) When the outside wheel needs to turn faster (e.g. - making a turn) the Aussie UNLOCKS, and lets the outer wheel rotate faster while still sending power to the inner wheel.
I'm really not trying to be a jerk, but it seems to me to be a pretty cut-and-dry kind of deal.
Jon
No.
either way it works great, even if I have no idea how it works! ;) All I know is I can crawl up some pretty large hills where I could not before.
locker
The locker is locked 100% when you apply the throttle. This is because the Cross pin shaft keeps the center couplers forced against the side couplers. When you corner and let off of the throttle the cross pin no longer loads the center couplers, so the couplers can move inward and disengage, thus allowing different wheel speeds left to right.
No, they don't simply lock when you apply the throttle.
Note that the center couplers can rotate half the width of the center pin relative to each other. This is the key to their operation. This means that the side that is rotating faster will not contact the center pin and since it has enough clearance between the center pin, it will be forced apart by the springs between the coupler and driver and thus will ratchet or unlock. Since one or the other wheel is nearly always rotating faster even if only a tiny bit, only one side is "locked" 99% of the time. It doesn't matter how much torque is applied as the faster wheel will always be unlocked unless the torque is high enough to make the driven side slip.
Autolockers work exactly the same way when you let off the gas (or in reverse) but in the opposite direction. When this happens, the side that is driving switches. This is why autolockers tend to pop and bang when you go from coast to accelerate and visa vera in turns. Autolockers switch drive sides every time you turn back and forth or go from drive to coast.
You can prove to yourself that applying the throttle does not cause them to both lock (unless a wheel slips) by increasing the amount of throttle in a constant turn. You will be able to hear it ratchet until you apply enough torque to make the inside wheel slip. Just don't go from decelerate to accelerate in turns as that will cause them to switch drive sides. When you switch drive sides when that side is ratcheting and apply a lot of torque, it will make a loud pop or bang when the teeth on the driver and coupler finally engage.
I think that you have a reasonable understanding of the basic operation of the autolocker and we don't disagree on the basics. However, I don't think that you appreciate how little time the locker actually spends where the tires are rotating exactly the same speed. I also don't think that you appreciate the dynamics of locker function when you turn back and forth or go from drive to coast and the fact that the locker needs to switch driving sides under these circumstances. This happens each time you let off the gas and then get on the gas or turn even slightly, such as changing lanes.
