Auto button not egaging in Climate Control
Hello all,
I have a 1997 40th edition with the Climate Control. I haven't had much problems with it except for but this afternoon. I can no longer select the Auto button (the light on the button does not turn green) and selecting the fan speed buttons do not switch on the fans. This means that I have no heat blowing in the truck. Although the rear heater fans work. When I select the AC button, the light does not light up as well.
Is there a fuse I need to check. The 40 amp fuse has continuity but there is a slight chip along the fuse wire.
The last thing I did this morning was to select the button with the top and bottom arrow and defrost. I turned off the engine and went to work. When I came back this afternoon, I couldn't get the heat to turn on.
Is there a way to reset the climate control? Do I need to check any fuses or relays or the blower motor?
I have the FSM. Any one know what pages cover the climate control. Do I need to get the 97 electical manual to trouble shoot the CC?
Any help would be appreciated.
Thanks,
BW
Welcome to the board. Anyone know if the auto feature disables if the A/C freon pressure switch detects low pressure? This would be logical, but I don't have an automatic HVAC on mine.
DougM
BW
A few months back I took the heater controls apart (trying to see if there was a way to disable the AC when the defrost is switched on). When I put everything back together, I had the same problem you are describing - fan buttons wouldn't work. Mine doesn't have the climate control - just a blank in it's spot. Under the blank were two push in switches. If I recall, one is supposed to be in and the other needs to be out. I assume it is the same with the auto climate control.
If the switches are not in the proper sync, then the fan buttons don't work. I took everything apart at least five times before I figured it out. Sounds like somehow your switches got out of sync. You may be able to take a small screwdriver and pop the button cover off the auto climate button and set the switches properly. Otherwise, the whole assembly may need to come apart.
Hope that makes sense.
Tom
Also, did you know that the auto climate control can be switched to a manual just with the flick of a switch? Some guys have been bothered by the constant system switching and other machinations and reverted it to manual mode. I was reminded of this while replacing the illumination bulbs and seeing the switch that says "auto/man" on the back of the HVAC unit.
DougM
I don't know the answer to your problem. However, for what it's worth, I would try pulling it out and flipping the auto/manual switch to see if that makes a difference. This is not hard to do, and will help in your troubleshooting.
I doubt you're dealing with a fuse if some of the lights are still working on the unit.
Note that normally when the switch is set on manual, and when the Auto button is pressed, the fan buttons don't work (like in your case). However, the Auto button still lights up green (not yellow - so not exactly like your situation).
See the following thread for some more info:
https://forum.ih8mud.com/showthread.php?t=31800
By the way, I have a spare HVAC unit if you can't get yours working and want to make me a lowball offer. Any HVAC unit (even without the auto button) from at least 1993 on up to 1997 will serve as a replacement for yours, because other than the buttons and faceplate (which are easily switchable) they all seem to be the same on the inside.
HTH :cheers:
You don't have to pull anything to make it work in manual mode. Just do the following:
1. Hit the OFF button
2. Hit any other combination of buttons, but just don't hit the AUTO button.
That's all folks. :D
I switched CC to off and selected a fan speed and vent mode and the blower motor is not working.
I tested the wire into the blower motor and no power was going in.
I took the Climate Control (CC) panel out and switched the Auto/Manual switch to Manual and tried the fan speed buttons but the blower motor is still not working.
I took apart the CC and will be testing it as per the FSM. A small plastic hollow cylinder fell out and I have no idea where to put it back. :doh:
I am going through the troubleshooting section of the FSM in the AC section.
Anyone have the Electrical Wiring manual. I need to know where the main heater relay is. Is it behind the other relays by the driver side floor?
thanks,
Bolon
There's more than one that could be the culprit.
This actually has a little more detail:
After troubleshooting the Climate Control panel, the panel did not have continuity in the Fresh/Recycle button and failed to light up those leds as well. I am not sure why this would cause the rest of the panel to fail since the circuitry looks fairly simple. In any case, the FSM says to replace it.
Anyone with a working 93-97 climate control panel, please email me and let me know how much you want for it. I am still going to try to figure which components on the circuit board is failing but I don't have the free time right now.
I haven't ruled out the heater relay yet but I will look for it again tonight.
Thanks for everyone who gave me some help. This board is great.
BW
By the way, the little cylinder that fell out is a spacer that sits at the top of the circuit board. Take a look and it should be fairly obvious where it goes.
Hi all,
My blower motor is still not functioning. Does anyone know where the heater relay is located? I have removed the glove compartment and the bottom cover of the blower motor but I don't see any relays. Do I need to remove the dash to get to the heater relay? What color wires are connected to the heater relay?
thanks
In the FSM, to troubleshoot a not working blower motor, it says to check the circuit breaker. Anyyone know where the circuit braker for the AC and blower motor is. I have a 1997 LC.
thanks.
