- Location
- United States
Going through the garage tonight and and realized I need to clear out some stuff to make room for more stuff if that makes since..... anyway here is a list with pictures attached. all prices are plus shipping unless you come and pick the item up. Im located in Austin, TX.
1. Flowmaster HP-2 Hushpower muffler. 2.5" inlet and outlet. I have this muffler on my 40 behind a 350 SBC and it sounds really good. real "throaty" . $75
2. 84 FJ60 fan shroud. In fairly good shape. some surface rust and a tear in one of the corners about 2 inches long. $25
3. 72 FJ40 small pattern knuckles, drum brakes, Locking hubs, backing plates, brake cylinders, small birfs, etc. everything you need to restore an early FJ40 to stock small pattern knuckles. $200 OBO
4. 15" electrical fan. push or pull but it has a pretty big shroud so it is better used as a puller on the motor side. has adjustable thermostat on it and mounts. not sure of the brand or the CFM. but it cooled my small block just fine. still works great. $40
5. Flow cooler short Small Block water pump. high flow/output. can come with two groove v-belt pulley. or i can remove it and sell em separately. pump-$50 Pulley-$15 Both-$55
6. SBC delco alternator mount. requires pre drilled heads. alot are, few aren't. Aluminium. comes with hardware. mounts on the drivers side up high. $40
7. TC style saginaw power steering pump with reservoir. has a single v- belt pulley and a SBC Mount. mounts on the drivers side down low. comes with hardware. will split up if you want. $50 for pump and reservoir, $10 for pulley, and $30 for mount, $60 for the whole thing.
8. SBC saginaw power steering pump mount. fits canned ham style pump. mounts on driver side down low.comes with hardware. $30
9. harmonic balancer 3 groove v-belt pulley. $15
10. 18" mechanical fan. never been used just bolted to a thermostat. $20
if you want more than one thing we can combine shipping. wil save some money. if you live in the suatin area i can meet you somewhere. let me know.
