aussie locker quick question
Chances are no, but you won't know for sure until you get it in the carrier and measure the tolerances.
I didn't need any with mine and when we installed a buddies he didn't need them either.
EDIT TO BE MORE CLEAR
You will use the washers that are already there, but you won't know if you need any additional until you get it installed in the carrier and measure your tolerances. Sorry if I caused any confusion.
I didn't need to change them on my install. I know some on the board have though.
Aussie Locker
Do i need the thrust washers? The directions say that toyota land cruisers do NOT use them.
Please advise where in the installation manual does it say not to use the thrust washers in a Toyota Land Cruiser installation? What is says is that you do not use the "Factory Thrust Block".
You use the thrust washers you remove from the diff for the installation of the Aussie Locker.
If you have any other questions please contact us at customerservice@aussielocker.com
Yes, that's correct. Although I think the manual also says to check the tolerances on those washers and replace them if they are out of spec, I could be wrong. If those washers are out of spec then the gap between the cam gears can be out of spec (per manual). Deformed/out of spec carrier is another reason for the gap to be out of spec. I never heard any these two scenarios happened to an 80. I didn't have to replace my OEM washers.
Any way, If you have no washers in there with the locker then I believe you have a problem that's just waiting to happen.
I guess I read the original post wrong. I didn't have to replace the ones from the spider gears. I just used the same ones without any problem. Some have had to replace them I just didn't have too.
