IMHO lockers will hurt you on ice. I just took my 80 up to over 8000 ft altitude on roads covered in ice. Much of the road was a foot wider than an 80 and frozen white all over. I still have mild 275 tires with a 3" lift. It never slid at all until I locked the center. Even then it was ok with the axles open.
At one point I had to back 200 yards down a road completely covered in wet ice. It was no problem. When it was time to turn around I punched the CDL and turned. This is when the pin 7 mod comes into play. I was wishing that I had done it. The truck handled better on the slick with the center open, but I needed the low range for the steep grades. I need to pull pin 7 in the CDL relay.
When the surface is slick you need to have as open a drive as you can to prevent the start of wheel slip, and use lockers wisely as needed. On snow, mud or ice the free exchange of power from one wheel to another helps to prevent the start of wheel spin and loss of traction, especially when turning. Differentials were invented for a reason. You only lock a wheel or axle when it has lost traction or is about to lose traction. Otherwise, let a well-designed machine do its job. This is the beauty of the 80's system of selective lockers. You only use them when you need them. The truck is incredibly sure-footed in open mode, and I can select center, rear or front lockers as needed.
In Prescott most 80's that I see are still soccor mom rigs. But many of them have 285-315 tires and a lot have CDL switch and pin 7 mod. Dealing with our slippery conditions I consider the total locker selection ability to be basic and necessary.
Here I see a higher number of Toyo 80's per capita than in the city and most of them have oversize rubber. Many of them have CDL switches and lockers. They are usually not lifted. The ones with stock bumpers usually have dents on the undersides of the bumpers. 4WD's get used here as a matter of daily life. We live that way every day. Ford, Chevy, Dodge, Nissan and Taco 4WD's are as common as flies on sh** around here. They are every other car on the road. All of them have one thing in common, open diffs all around for the best traction on slick roads.
I love my lockers, but they are a sword with two edges. Use them when you need them, but leave them off most of the time. I follow the old war line with a twist; I will lock no truck before its time.
