After taking everything apart when my Aussie locker would not unlock this is what I have found and can't figure out what to do. It worked fine for two years up until this point.
1. The contact patern on the ring and pinion is dead on.
2. I replaced the pinion shaft with a new Toyota part.
3. Each of the two factory shims under the side gears measured 0.076.
4. The center gap between the Aussie Locker prior to tear down was 0.150.
- Aussie states this should be between 0.145 and 0.170
5. My clearance between the new and old pinion shaft and the locker spacer on the ring gear side is .033. The clearance on the opposite side is 0.027.
Aussie states that the clearance should be between 0.006 and 0.020.
Here is my problem, if I replace the 0.076 shims with even the thickest Toyota shim (0.083) that will bring the pinion to spacer clearances to 0.026 and 0.020, still not very close to the Aussie reccomended of 0.006 to 0.020. This will also effect my total assembled gap between the locker clutches to 0.136, off from the minimum of 0.145.
What to do?
Has anyone else had issues with not being within acceptable clearences?
I don't believe anything is wrong with either the locker or my diff. case. But, I could be wrong.
I need to get this fixed so I can start on my turbo project.
What to do?
