I just finished the install of an Aussie Locker in the rear axle of my 74 and took it for a test drive. I got the expected clunks and bangs when turning under acceleration/deceleration. What concerned me was a clicking noise when driving straight ahead. The clicking is directly related to the speed driven (gets faster with increasing speed). During the install the center gap was measured .167 (spec is .145-.170) and the shaft to axle gear spacing measured Left-.010 Right- .006 (spec is .006 to .020) . After spending the last two hours scouring 10 pages of search threads I'm still stumped. Any ideas what is going on inside the diff?
For additional background during the install I also installed a 3.70 diffs from a 60 series with a new pinion seal and conversion flange since it has 3 speed pattern driveshafts. I tightened up the preload on the diff side bearings and set ring gear backlash back into spec. Also did a rear disk brake conversion from Sky Manufacturing. The right rear wheel bearing was also replaced along with both axle seals.
