Aussie Locker and CDL switch
Monroe, GA
Shortly after I bought my '97 LC, I installed the CDL switch and did the 7-pin modification. And, as far as I know my viscous coupler functions correctly. Up until now, most of my off-road driving was usually in 4-Hi, with the CDL engaged.
Here's my question: Now that I've installed an Aussie Locker in the rear, should I still run with the CDL engaged (locked), just let the VC do its thing as needed, or does it really matter one way or the other?
CDL should always be engaged when on dirt, the rear locker won't help you at all if you spin a front tire without CDL. Ask me how I know!
Here is the break down for lockers:
Open/open/open: if any one of 4 wheels lose traction then you are SOL
Open/open/rear: if any of 4 wheels except for one of the rear wheels lose traction then you are SOL
CDL: if 2 wheels or 1 wheel from each axle lose traction at the same time then you are SOL
CDL+Rear: if both rear wheels and 1 front wheel lose traction then you are SOL
3x locked: all 4 have to lose traction for you to be SOL
CDL will get you in and out of 70% of the trails out there, CDL plus rear will get in and out of 95% of the trails out there. 3x locked rigs can go just about anywhere if the tires and driver are good.
