Aussie install help
Flagstaff, AZ
Now that I have my engine out I'm waiting for the other one I have
sourced I decided to go a head and install the Aussie I bought before I ran into all the engine trouble.
My brother and I pulled the third while he was in town and I decided to try and install it tonight.
I got the third on the bench and pulled the pinion shaft and got the gears and thrust washers out. I installed the locker gears, thrust washers, and spacers and checked my gap tolerances. Way too tight. I can't fit .002 between them. The minimum is .006. I've pulled them out and reinstalled them in several configurations to see if it makes a difference. Nope! I can freely spin the drivers side but the passenger side is so tight it takes a lot of force to move it. Even though I can move the drivers side I can't get a proper gap. I can slide .002 in there.
The thrust washers, bearings, and pinion shaft all look good. No excessive wear. The diff oil was in great shape and at the right level. No signs of wear. No excessive metal shavings.
Suggestions?
You're going to need thinner shims. Mine was WAY to tight so I ordered a bunch of extras(different thicknesses) from SOR and found the correct thickness I needed. PM me if you need some, I still have a few left.
Good chance you need the thinnest one. Post your thrust washer thickness. If you need second to thinnest ones both me and jp_waltz have a set.
Bingo. QBall had the forthought to get all the sizes available. Good thing because we needed them to make it work.
I'll measure them and post the sizes.
I'll be in touch.
One is 1.99 mm and the other is 1.74mm. My caliper measurer is low on batteries so the screen is dim. If those numbers seem off ill get another battery and post again.
It's not uncommon to see different shims installed but all the more reason you need others to get it within spec.
I won't be able to get to my shims until Thursday. I'll measure what I have and let you know.
Here are the washers I have.
Measurements are +- .02mm.
Here are the washers I have.View attachment 1058573
Chances are, mine will be similer to what Chang has. Im pretty sure I used the thinnest shims on as well. Might be worth a call to SOR to see if they have the "thinnest" shim available. They're not much money, I think like $5 or so.
According to my math your current shims are 3.73mm and you needed additional .08mm or .04 on each side to reach the minimum .006 to .020 gap for the spindle. So the new shims need to thinner than 3.65mm total. so the 1.76 and 1.72 shims should do the trick with the total thickness of 3.48 which should put you comfortably in the middle of the gap at .0125mm.
But to confirm that those shims will give you the correct tolerance, fully assemble the locker and measure the center gap to confirm my math. The center gap needs to be between .145 to .178mm.
I'll do that.
Thanks a million guys.
It just hit me that one of your shim is already at 1.72 so you probably will only need the other 1.72 or 1.76 shim. Either way it looks like you need to take off .20mm off of shim.
Turns out my thinnest shim is 1.78 (+\- .02). Let me know if you need it.
Okay so here is what I have learned. I went ahead and installed the Aussie per the instructions. So cool! I was surprised how easy it really was. I went and got a new battery for my caliper and remeasured everything.
The thrust washers both measure 1.93mm (+/- 0.01).
I cannot slide a .006 inch gap between the spacer and the pinion shaft (The tolerance is .006-.02 inch.) Therefore, as suggested, I need thinner thrust washers. On the drivers side I can slide a .002 inch barely in there. So I've got to have thrust washers that give me at least .004 inch more room.
After assembling the Aussie my center gap measured .154inch (the tolerance is .145-.170). Which means I've got some room to play with.
Bingo! You're almost there :cheers:
Okay if I did my math right here is what I need.
The smallest I can go is 1.76mm thrust washer, which means my center gap would be .168 (just inside the spec).
So I think I need the 1.78mm from jp_waltz should work.
