aussie in a FF?
Junk
Mod Emeritus
buggerville nj
Would an Aussie locker work in a FF application or does it have to go into a SF rear? The 80 I had ARBs in, so this is the first I'm starting to look at other options for the 45.
do FF rears use cone washers? My old drum front would loosen up all the time, for lack of cone washers. I would tighten up those bolts every time I went wheeling. Since I have changed to a disc from the problem has disappeared. Good thinking :beer:
Thanks Bailey. Busta - yeah, the 77 FF rear had the bolts, but I got a hardened stud kit from Front Range and got the cone washers from Cbizkit.
yeah just keep checking the tension on the studs... use a little loctite too.
my detroits done a few 1000 miles in the FF and not had a problem, but it's smoother than the aussies from what i can gather
I'm running a Lockright in a FF rear and a couple of fronts (FF of course). No problems.
Mark...
