Atlas with yota d-shaft?
Amherst NH
Called someone at Advanced Adapters and asked them if they make a flange for the atlas that will adapt to a landcruiser driveshaft. They said no. Anyone disagree?
Ditto. I have their flange on my Orion HD - 32 spline output. Except I recollect having to have them mill down the seal neck area to match the Orion - don't remember? Then had to further mod the disc parking brake kit and drill my own pattern.
I do remember him trying to convince me to upgrade to a 1350 CV - and while I probably would have if I had the funds, I wanted the d-shaft to be the weak link. Might rethink that now that I'm putting in a 14 bolt :D.
Thanks I'll give them a call. Anyone use the 203 doubler with the atlas? I've broken 2 rock boxes on the trail and am going a different route. Seen some info on broken input shafts for the 203 adapter shaft to a stock t-case but, but nothing about the 203 to the atlas.
The 203 is a beefy, I have friends with the 203-205(Lomax) in them and I would all but say its unbreakable... The 203 should be fine in front of an Atlas...
