Anyone out there running one of these? It's a 4 to 1 pre assembled direct bolt up tcase by Atlas..I haven't seen them and can't find them on their website, but I ordered one instead of my Orion.
If Poser's got one it must be good!! The HD Atlas transfer case is simply a 32 spline output front and rear, no matter the gear ratio.
I have a 4.3 low range Atlas with the 32 spline outputs in my Land Cruiser and have been beating on it since 2005 without issue.
They are a nice transfer case.
Not to sound like a total NOOB but what are the advantages over the Orion and this.. The Orion was my first choice but going to take a bit longer to get done so I went with one of these.If Poser's got one it must be good!!
Thx for the info.. you are always on top of things
fwiw, the atlas t-cases come in 3.0, 3.8, 4.3, 5.0 and 6.0 ratios. there is also an atlas 4spd acse available with multiple gearing options.....
It's the orion strong as the Atlas is . ?
What puttin a Atlas 4speed behind a A442F? ive seen the adapter the offer for the tacomas behind the r150
Not the unit that is designed to use stock output shafts...
The HD unit is using 32 spline output shafts...
