At Long Last! I Have An 80 Series! Now I Gotta Build It.
They’re also gonna rush a lot easier now. And why I suggested painting.
Technically polishing steel makes it more rust resistant.
Beyond visible pits and valleys that trap dirt and moisture that might start the rusting process there is also less surface area which, on a microscopic level, means even fewer pits and valleys to the nasties.
cover those smooth bois in some grease, as happens when you turn your wheels, and that makes the process even slower.
Anywho the whole axle housing will be getting some paint in the next day or two and I did have plans to cover the exposed metal bits that do not get hit by the seal.
well my 3D printer sleeve driver worked a treat.
probably didn't need to put the driver they send with the sleeve on top but it seemed like the right thing to do if i was gonna be smaking on it
Honestly a few moderate whaps with the deadblow and it went on pretty easily
Little snip with some diagonal cutters and grabbed the lip with some vice grips and twisted the lip off pretty clean
not realy sharp or anything.
I approve of the speedi sleeve
Yes I realize I maybe put them on the wrong direction when you think about how they slide into the seal but the edge where the lip was is not really sharp at all after removing the lip.
I don't think it will have any issues sidling into the seal
