Getting these hoses off were a bitch in themselves… does anyone have any old Indian tricks for getting them back on? Only thing I can figure is taking the entire front of the truck off
You have no idea how much frustration you saved me. I’m indebted.remove turn signal under headlight
remove 10mm bolt holding that metal tube assembly (you can see the bracket in your photo- the front facing side has the nut)
pull out the hardlines and put hoses on cooler side
slide back in and mount
push on the remaining two hoses
if you can manage to fish out w/ all hoses attached, even better. attache all hoses and fish back in- easy.
For the lines on the cooler side, can I use the same 3/8 AT hoses? They look and feel different from the ones on the rad side.remove turn signal under headlight
forum.ih8mud.com
Perfect. Really appreciate you.all 3/8
actually, the correct OEM is 10mm hose but...
the inner hoses are double wrapped with sleeve and coiled plastic
the outer has a sleeve i think- but they may have been changed, which might be why they feel different.
this thread was really helpful - I updated at the end
Transmission hose replacement using non-OEM parts
Since I've found this community to be more than helpful in getting my FZJ80 in tip-top shape, I wanted to share some experience replacing the soft transmission hoses using non-OEM parts as almost all are discontinued. This project started after one of the hoses developed a slight tear and...forum.ih8mud.com
