Are my CV boots leaking and rear hub and bearing leaking?
Yup. Hook on the machined lip on the inner joint. I hold the hook on with a hose clamp. 3-4 hits and it should pop out.
i was going to use zip ties, but used my dad to slide the hammer while I was holding the hook.
did you rotate the shaft at all?
large hose clamp sounds genius!
No need to rotate it while popping.
Usually they pop right out with a seal puller. Then tap it in with the hub dust cap.
