Are My Back Wheels Binding?
Crescent City, California
Are my rear wheels binding? Of late I've had terrible gas consumption - down like 50% - and I noticed my right rear wheel a little hot and thought the parking brake was binding. I put the back up on jack stands and with the transmission in neutral I'm turning the wheels but I have no idear just how much resistance there should be. I am healthy and average strong and I can only just turn the wheels with one hand (no on the tire of course) with my hand in the openings in the wheel.
I have the FSM but see no fish scale measurements without removing the wheel as you would with a bearing replacement.
Does this resistance seem reasonable?
A couple years ago I was dealing with about 120-150 miles per tank. After a ton of troubleshooting it ended up being a full-length tear in the intake hose and a bad temp sensor.
Dan made some money and I get at least 100 miles more per tank now.
Maybe it's not the wheels is all I'm saying...
How do you teat the temp sensor? I've replaced the air intake system which is what I assume you mean. Did you clean the injectors too?
I had a frozen piston in my rear caliper. You could determine that by pulling rear wheels and checking pad wear. In my case, my relatively new inside rear pad was toast.
Good Luck!
Yeah, but the intake hose shouldn't be causing the wheel to get hot.... ;p
