Arb switch install = steering wheel removal ??
Canyon Lake, TX
I'm putting in my ARB switches this weekend and want to put them in the 3 spots beside the dimmer. The FSM states that the first step is to remove the steering wheel. Is there any way around this or must it be done ? Will a steering removal tool from Harbor Frieght or Auto Zone do the trick ?
Any other suggestions would be appreciated. I did a forum search and saw the other places (under heater control) people put them but I like the way the ARB switches look in that spot.
Can't wait for step #6 :beer:
You don't need to pull the steering wheel to get to the dimmer switch, maybe the headlight/highbeam switch. I know on the pre 96 models you just pull a couple of screws and pop the panel off. Can't imagine its much different on the later models.
Sorry, but I forgot to mention it is a 97. I removed the screws that I could see this morning and the lower panel was still stuck on there pretty good. I glanced at the FSM and it talked about the steering wheel but it sure seems like alot to do to get to that dimmer panel.
You can get it out. I removed the entire dash board on my 97 without taking the steering wheel out. I recall having to screw around with the tilt to get it out, but it can be done.
Took about twice as long to figure out how to get it back in though.
I just installs some fog switchs in that spot. I don't recall a screw to remove. Just rapped it from the left side until it popped off. It all snapped right back into place as well. Maybe mine is missing something but it was very simple.
