The front locker is ordered and I'm sitting on my thumbs waiting for it and the bearings and knuckle kits, etc., to arrive. Everything's been cleaned and painted.
My air plumbing system is a little out of the ordinary..... kinda' like me. 'Haven't seen anyone else doing it quite this way, so thought it worth posting. It has worked quite well in the rear locker for over a year, and the air leakage is next to nil.
The fittings are rated at 0 - 150F. I imagine that's conservative. 'Never seen it below 16 degrees here...... and it worked fine at that temp..... YTMV. IIRC, the hose I'm using is good to 300#.
The beauty of this system (not to mention how damned easy to plumb) is that if you have a damaged line.... or a damaged solenoid or switch..... you can make a field repair in minutes.... or plumb around the solenoid direct to the locker, if that's what's needed to keep going. I'd say, I could bypass the solenoid in less than two minutes. Cut a line ??? Shouldn't take five minutes to repair/replace. I guess time and trail testing will eventually point out the weaknesses, if any.
http://sparkgap.homestead.com/OnBoardAir.html
John Sherwood '79 FJ-40
Charlotte, NC TLCA Upstate Cruisers
