arb marker lights
Are the ARB marker lights designed to be hooked up to the day time running lights? or the signal lights?
either way you like. Just pick the correct wire behind the oem turn signal/running light bulb. Maybe it could be a poll, but I think most arb owners use them as turn signals.
Still need to see your rig since you put that bumper on!!
Long time no post for you,
Hope things are good!!
Later,
For the front ARB bumper, the lights are designed to work as turn signals. Some have reported melting the light housing due to continuous usage as marker lights.
If you want to use them as both (blinkers and parking lights in the US), you need to change the bulb out to a smaller bulb to avoid melting the lense. Bulb type 67 IIRC...
There is at least one thread (older) that details out what connects where. Not sure if it would apply however to Canadian models with DRLs. If you can't find the thread let me know...I have it "subscribed" somewhere in the melee of threads...
The thing i dont understand is why ARB sends these marker lights with wiring connecters that dont even match up to the 80 signal lights.....
so i have to end up cutting off the connectors and using butt end connectors and heat shrink??
Anyone know what color on the ARB marker light goes to which signal light wire on the 80?? Id like to hook them up just as normal blinkers, no disco effect, no changing light bulbs.
Cheers
Cheers
Hill,
Here is the thread I was thinking about: https://forum.ih8mud.com/showthread.php?t=48776
Post #4 tells you what wires go where but this is to get the lights to be parking lights and blinkers and requires the bulb change out (super simple and cheap). I did this so I don't know for sure what to connect up just to make them blinkers. Didn't the ARB come with instructions for just that? I can't remember.
As for the connectors...You are splicing into the existing wire for the signals/parking lights depending upon what you ultimately decide to do. With the ARB you should have received some "scotch lock" connectors to use...Basically you put the existing wire in on one side, slide the ARB wire in on the other side, and clamp the little clamshell lock down. Then you can protect that how you choose (heat shrink tubing, electrical tape, liquid electrical tape, whatever. There should not be a need to completely cut the turn signal wires!
It helps to take the turn signal/parking lamps out to have access to the wires. Slee's site has a tech article on adding blinkers to the parking lamp which details how to get the parking lights out.
They are both isolated grounds so it doesn't matter. Light bulbs have no polarity and the housings are all plastic. If you want to get totally anal, you could use a meter to figure out what color Toyo used for the bulb socket "hot", but I don't see the point.
Has anyone tried swapping in the dual filament 1157 bulb sockets into the ARB signal housings?
I wonder if that'd be low power enough for a parking lamp without melting the housing.
