ARB locker integration
Now that's what I was looking for. Thank you very much for all the help Christo. Once I get this thing to work, I will put together all the steps of how I did it.
Riad,
I strongly suggest that you build yourself a test bench with a 12v power source. You can use a spare battery or a small battery charger or an AC-DC converter. Get a multi-meter, some 12v relays, switches, 12v lights, and some wire and start experimenting in a controlled environment. After you are certain that you understand how everything is working then move the components to your truck; not before.
Good luck and keep us posted on your progress.
-B-
OK dumb question, where is the connection/splicing point for the Dash illumination and ignition for the ARB isolation switch, wires: RED-YEL and BLU-WHT?
I am talking about the compressor switch. It needs to be connected/tapped into ignition and illumination. What is the best place to do this, lets say on the left side of the steering wheel?
EDIT: I Pulled off all the wiring from the ARB wiring loom for the switch 1 and 2 for the solenoids. I intend to use the supplied ARB switch to power up the compressor. They called this switch isolating switch (not isolation, bad wording in my part :D ).
Original ARB Wiring Loom
Stripped off Wiring loom
OK guys, I finally got the instrument panel DIFF LOCK lights working with the factory switch :bounce:. I thought I would give you guys an update. The following is the final diagram for the wiring.
This diagram is for 1997 LC, 40th Anniversary Ed, Production date: 01/97. ECU, wiring and Pin connectors or location(s) may vary or be different in other models.
Essential Parts list:
1. Qty of 2 DIFF Lock Bulbs.
2. Qty of 2 Sockets for the bulbs.
3. Qty of 2 12V 5A relays from Radioshack. You can get this one or this one . They are essentially the same thing (Model: 275-248 and 275-248A)
4. A Project Box and PC card combo. Some thing like this one (Radioshack).
Soldering can be done for the wires and the realy legs.
You have to take out the instrument cluster to do this. Look in your repair/shop manual for how to remove this. I didn't take out my steering wheels although the manual mentions it in the removal steps.
The DIFF LOCK ECU CONNECTOR is in the right side kick panel. As shown in the picture, the relays have to be connected to the designated pins for the instrument panel lights. Consult your Electric Wiring Diagram to see over all wiring. I simply used plastic tie wrap to tie the ECU and the project box (ECU Emulator) together. Seemed secure enough for me. You can always use your own innovative thinking to mount this thing :). ARB Solenoids are easier than this. There's a link on the technical section of which wires are tapped into the factory rotory switch (12V feed). I'm not gonna go into that. I need to borrow my nephew's camera and take some pictures of the lights.
Thanks every one :) .
Thanks Riad.
If it done, can you please provide us a complete detail on the whole installation, wiring, and connection that can be added on the FAQ list. Thanks. :D
edit: Is the Diff Lock ECU already installed in the right kick panel or you bought and installed it yourself?
Was that question ever answered on the ECU already being in the truck? Is it there even though the truck was not factory locked?
AFAIK the Diff lock ECU is not there for the trucks with open diffs. I did not have any such ECU. As a result a circuit had to be created with relays to integrate the locker inot the factory instrument cluster.
Hi Tony,
I can confirm that the above wiring diagram using off-the-shelf relays works great on my '96. Let me know if you want to go that route, as I should have the right connector you need to make your ECU "emulator". Have pics in my profile of the loom and results; cheap and easy mod, just takes a little wiring skills and triple-checking to keep from screwing anything up in the instrument cluster.
IH8MUD.com
:cheers:
Steve
