ARB Intensity - "knockoff" or "unbranded" versions.
Looking at the ARB website, these are equivalent in size to the bigger AR32.
I have a set of the Aurora in combo beam, I got them off Alibaba. I told them I wanted to order one pair with a harness as a sample to test. The lights were $72 each, harness was $16, shipping $115, paypal fee $10 and they took about 10 days to arrive. I've seen the $149 ARB knockoff from amazon and the Aurora are way better quality. I should have them installed soon and will add some pics.
These look similar too! Anyone run these?? A guy on the Tacoma forum does and they’re inexpensive
Xprite 96 Watt 9-inch Cree LED Fog Spotlight and Round Work Lamp with Roof Bar Bumper (2-Pack, Red) https://www.amazon.com/dp/B017L9MF0A/?tag=ihco-20
If those Aurora’s weren’t so pricey to ship I’d definitely like a pair, quality looks to be quite nice
Did any of these come with the additional fog pattern lens covers?
In Februari 2018 I will be traveling through Sweden and since there will only about 5 hours of daylight I figured I needed some extra lights.
Did some research and came across the "LED" knockoff's.
Today I received my pair of the lights (with clear lenses).
I must say I'm impressed by the build quality and the amount of light for this price.
I've only tested them in my office, but will post more pics later.
I was interested in power draw, so I hooked them up to a power supply. First 11.9V:
Power consumption: 134.47W.
Then 13.4V:
Power consumption: 129.98W.
While I was researching these lights I could not find a whole lot about them soooo.....
I will be doing some more testing on these lights like:
- Power draw at different voltage levels;
- Temperature of the lights measured with IR camera;
- Some Lux/Lumen measurements if I can get such a device;
- A lot of pictures (manual exposure etc).
I'll share some first impressions with everyone.
The lights come nicely packaged and include all mounting hardware you need + some allen keys.
1x 9'' LED light;
1x Clear/spot lens / flood lens also available;
1x Mounting bracket;
1x 6mm hex/allen key;
1x 4mm hex/allen key;
2x M8 hex/allen bolt;
2x M8 lock ring;
2x M8 ring;
2x M6 hex/allen bolt;
2x M6 lock ring;
2x M6 ring;
1x M10 bolt;
1x M10 lock ring;
1x M10 ring;
1x M10 Nut;
You've already seen the front in my previous post, so here is the back:
The bracket & mounting hardware:
The holes for the brackets do not align very well, but with a bit of force you can get the bolts straight and in.
The light mounted on bracket with clear lens:
The amount of light it puts out:
I could not make a good reference picture with my phone, because it was completely black.
The house you see in the distance is about 70 meters/yards.
More info soon.
thanks for the photos, what did you do in terms of wiring and switch?
For now I hooked the light up to a power supply.
I have a fancy way of connecting and switching the lights, I'll show that when it is finished/working.
So a quick temperature test today. The data of this test is not completely valid.
In one of my previous posts you can see 11.9V / 11.3A which equals to 134.47W.
For this test I used some 10A test clamps instead of the higher rated clamps I normally use.
This resulted in 12.0V and only 9.5A which equals to only 114W.
The clamps became quite hot and had a high resistance. I saw this after an hour when I tilted my IR camera down.
I was focused on the light and not my test equipment. Could not see a difference in light since it was still way to bright on the white wall.
Whilst this test is not completely valid I'll still post the results.
The light and connection:
The hot clamps:
The test environment was not normal for these lights but was carried out in my office.
Abient temp was about 23C / 73.4F and NO airflow at all to cool the light.
The light was powered by a lab power supply at 12.0V.
Temperature was measured at the back of the light on the cooling fins with an IR camera.
Here is a graph of Time versus Temperature:
On the X axis there is time in seconds.
On the Y axis you'll find temperature in degrees Celsius.
Conversion to Fahrenheid:
0C = 32F
10C = 50F
20C = 68F
30C = 86F
40C = 104F
50C = 122F
60C = 140F
70C = 158F
80C = 167F
90C = 194F
And a pic of the heat distribution at 77 degrees C / 170.6F:
The aurora 7" led light are higher quality than the regular knock offs. They are the same as the light force 215 7" led lights which retail $300-$350 each.
See link:
RIP OFF OR NOT? THE L.E.D WAR THAT ROCKED THE WORLD - Unsealed 4X4
The light force 215 7" led light were rated as good as the ARB lights.
The minimum buy is qty 10. The price per light is around $90. I am interested in 4. Anyone want to split the order?
I'd buy a couple... email me at huntsonora at gmail.com if you decide to put something together
Based on some interest, I will request a quote for 10 Aurora combination Spot and Flood lights. I have never done this so I propose i get a deposit for the shipping only. We can split the shipping per light. Once the lights are here, i will conduct an inspection and determine if there are any apparent defects. I can then confirm how many you want and you can pay for the lights(at cost) , insured shipping plus a fee per order (~$10) for my time. Message me via ih8mud if interested. If you decide not to not buy them, you are out the shipping cost.
PM sent
I just got the quote. Its $1155 for 10 to my door shipped. $79 per light, $320 for shipping and $45 paypal fee.
So your cost is $115.50 per light. Actual packaging and shipping cost on your preferred carrier from 97007 plus a $10 fee per order ( to cover my costs for testing every light and handlng).
I have 6 lights spoken for. PM me if interested.
I will need $32 per light (shipping cost) as a desposit before I order.
Then 13.4V:
Which wattage lights did you purchase?
