Should be black. Just check which one has continuity to the center pin of the DC plug, that is the power.
Hey I forgot about this. You still need that info? I can go meter mine, I've got it here with me now.![]()
Well, I don't think I can help, I have the new three pin plug. The two side by side spades are power, the odd one out is ground. The entire cord, plug, housing is fully molded, no luck on seeing the internal wire color.
FWIW the power wire appears to be the one with the white strip on the outside of the wire mould, maybe yours is the same.![]()
WHOA !!!!!!!???????????????? I think you guys have confused me and or yourselves...
...The problem is that the vechicle side plug is gone , cut off and Im trying to install a new plug...
Just you
The Engel plugs BOTH have 3 prongs, however the AC uses a standard parrallel scheme (similar to every computer, monitor, etc cable) and the DC uses a different setup...
Where were you able to source a new plug? I've been looking for one and never had any luck. Share the wealth![]()
