ARB diff setup problems - real time help
Hi Guys, I'll post this here as my truck uses the same diff as the 80 series.
A shop installed an ARB in my 8 inch front diff - high pinion. Everything is new, R and P, bearings, oiler, ARB locker etc. So - it was set up about 2 weeks ago and installed in the truck. I went wheeling for about 20 minutes last weekend and then noticed a bunch pf play in the pinion shaft this morning. I pulled the diff and see that the pinion moved into the locker housing and scored it - lots of metal in the oil. I didn't wheel it hard.
Before I bring it back to the shop I'd like to have an idea of what he could have done wrong. I felt the pinion after he set it up, felt a little tight but he said it would work in a bit once the oil got in. He said the backlash and preloads were all set up right.
Any ideas?? colapsable spacer problem?
This is all I did while wheeling - not even a workout:
YouTube - HZJ79 Landcruiser Burntlands 2008
Thanks
Louis
Not saying this is the problem, but what *could* have happened is one of the pinion bearing races wasn't fully seated into the carrier. Then when you put a decent load on it, the race fully seated and this allowed the pinion to move.
The nut is tight and didn't back off - I am leaning to the bearing cup not being seated properly. As you can see in the video I did not wheel the truck hard at all - and that was all I did since I had the locker installed.
We should have it apart tomorrow and maybe we will have a better idea of what happened - what bastard thing to happen - i was supposed to go wheeling friday and saturday.
