ARB compressor problem
Reno, NV
Technically not true 80 tech but its on my 80 and this section gets a lot more views...
Have an ARB big twin compressor running both F&R air lockers. Unit is about 3 years old and until this year has been running well. On this years Rubithon, I noticed it would cycle on for a few seconds every 30-40 seconds, with or without lockers engaged, as long as the compressor switch was activated. Thought I had an air leak at one of the locker O rings but ruled that out after the compressor would still cycle with both lockers off.
With the twin compressor, they will pressurize their internal tank and then shut off. This internal tank isn't big but does hold at least a few L of air. If I let the compressors pressurize, then shut them off, I cant hear an air leak anywhere....which seems odd.
Had some time tonight to look into it and discovered one of the compressors is not running at all. Checked wiring at both compressors and they are getting power. Wonder if the failed compressor is causing the cycling. Has anyone else with the twin compressor had one go out? I don't know where to go from here. Maybe email ARB?
More info:
After typing up this thread...had a hunch that air was leaking out of the intake on the failed compressor. To confirm, I pulled the intake filter and stuck my thumb over the inlet. After a few seconds, I could feel pressure building up and when I let go there was a noticeable "poof." The leak is definitely at the air intake of the failed compressor. I guess still better than replacing one of the O rings in the actual locker.
I'm going to build on this thread. Have f&r Arbs going thru relays to o.e. dial. Have the mini compressor going to a repurposed hazard switch.
All worked well the last few times, then this last weekend, rear worked fine but if I turned front locker on, compressor would keep running as if there were a leak. Would continue running when I switched to rear only. turned off with lockers completely off. Multiple attempts yielded same results
Once home, disconnected line at axle and plugged, compressor kept running,so diff rruled out.I could hear air leak at solenoid/ compressor. Pull air line from solenoid and put thumb over hole....still leaking.
Thinking it's connection to compressor, I remove pressure switch so I can spin solenoid off and find compressor has air in tank when pressure switch pops out.
Put it all back together and now compressor won't turn on. Jump it at the plug and compressor runs
mine has been confirmed that the issue it wasn't running was the pressure switch. will hopefully find a switch tomorrow at work and then i only have to diagnose the leak issue i was having
