I have front and rear arb locker in my FJ60
Question:
Will the front locker out of my 60 fit into the rear of my 77 fj40 ??
Question:
Razor said:I have front and rear arb locker in my FJ60
Question:
cruiseroutfit said:RD02 is the front FULL-float unit - can only be used in front or FF rear applications.
RD08 is the SEMI-float unit - it can be used front or rear.
So yes, alot of people prefer to have two RD08's, so they could swap if ever needed. I run two RD02's, but I have a FF rear. The RD02 is marginally stronger than RD08....
Razor said:Its got RDO2's Front and Rear..
thx for the help..
Landpimp said:so you have a rear full floating axle? that would not be stock for a US fj60.......but it might have been added.
Razor said:Well,
I am reading it right off the reciepts from ARB...
RD02 Landcruiser Full FLoat... $501.19 each....
Razor said:Well,
I know that cal put some time into every piece of the entire rig, will these go in the front of my stocker 77 FJ40
Razor said:Well,
I
I
Landpimp said:BTW nice price on the ARB.......thats like cost![]()
Razor said:Its Flatt behind the caps...whats up here ?
I can't get anymore info out of cal...sick of my questions I guess.
Landpimp said:then its a SF![]()
Razor said:I don't know the difference between a SF and FF
now, how are the RD02's in a SF ??
Landpimp said:for not knowing you need to give me one of the cruisers
someone care to give a simple explanation? I suck at explaining.
ah hell I'll try. A SF(semi flaoter) carries all the weight and load on the axle shaft/bearings and if the shaft breaks the axle can come out of the axle tube.....not fun, but SF cruiser axles seldom break. To remove a rear axle shaft you must take the cover off the rear diff and take a C-clip out then remove the shafts.
A FF(full floater) carries the weight and load on the axle tube not the axle shaft, baiscly its like the front end of a Cruiser. If a FF shaft brakes it will not slide out of the tube. To remove the shaft on a FF....just unbolt the rear hub and slide the shaft out, no c-clip in the diff. Also a FF diff has no cover on it like a SF.
hope that makes sense. .....and its prolly not 100% correct
FF= cool and safety factor, also can run OEM diff lock.
that said I have a FF in my 45, it came that way, I would not bother to do it again.
the RD02 will NOT go in a SF
