Anyone Using This Steering Shaft?
Columbia, SC
http://www.flamingriver.com/index.c...tegory_id=120/home_id=85/mode=prod/prd211.htm
I was thinking of buying this for my saginaw conversion. Is anyone using this shaft or recommend another one. I know borgeson will make a shaft as well but did not know the price or if it is any better. I don't want to make my own unless I can make it with a slip shaft and it saves me some money. I don't mind spending money on steering parts, I don't want to die:eek:
I know their is all kinds of tech in the search but I wanted to hear from people that might have used this particular shaft.
Thanks
Jeremy
I use borgeson shafts on all of my cruisers They are simple dd design and the ujoints seem to last. I use a 36" slip shaft from borgeson the u-joints are 13/16 saginaw spline to 3/4 dd and the other end is 3/4 dd to 1" dd . I could probably find the correct part #'s if you need them . There are two different splines on the saginaw boxes .The larger 13/16 is usually on the 4 bolt 4.25 turns to lock box.
Did you have a 3/4" DD for your steering column shaft? I thought the factory shaft was a little larger than a 3/4" smooth.
I found the part #'s for the shaft and steering box joint, but what did you use at the column? I was planning on keeping my stock column, so for the steering shaft (borgeson) you mentioned I would need a 1" DD to 3/4" smooth. Or did you grind your shaft to make it fit?
Thanks for the help.
Jeremy
I did some researches on this subject and found that Flamming River makes high quality parts too, I beleive the both AA kit and SOR are using Flamming River parts. The best prices on these are at Summit Racings that is where I'm getting mine.
/td
Thanks mustard, I just checked the prices for what I need with Summit.
$192.50+ shipping using Flaming River u-joints and the 36" Borgeson telesc. shaft. I think I might try this route and weld the 3/4" smooth bore end to my steering shaft.
Thanks for all the help guys, I am trying to put together a Christmas wish list for my family. I told everyone this year to get me cruiser parts. Looks like this will be a trend for many years to come. I love these rigs!
Summit Racing Parts List: http://store.summitracing.com
BRG-450036 36" telesc. steering shaft (3/4" DD to 1" DD)
FLA-FR1707DD Flaming River u-joint (1" DD to 3/4" smooth)
FLA-FR1719DD Flaming River u-joint (3/4" DD to 13/16"-36 spline)
I am using an AGR SB2 for an 80' up Heep CJ Part #262357 (hate to use Heep parts, but got a killer deal on it.)
Got my pump bracket, pulley, and belt from Lance @ Iron Pig Offroad.:beer:
Jeremy
I pulled my stock column out and machined flats so a normal dd u-joint would fit. Had to take the diameter down very slightly. (I used a lathe but a grinder works too.)
flaming river DD slip shafts:
here
This is what I used. Looks like about the same price as Borgenson.
Don't try to weld the Flaming River smooth bore u-joint to your shaft, it will smoke the seals. I drilled and tapped mine, after things started to melt. :doh:
Do you feel o.k. with that tap holding it together?
Not questioning your work, just want to make sure this is the best way, and not what you did since you already had the parts and realized you could not weld it.
I feel better than I did with the welds. I used a #6 grade 8 internal hex set screw with a jam nut to lock it in. With PS I don't think that component will see that much sheer stress.
I don't really know what the OEM shaft end looks like, mine was torched off by the PO. But I guess the alternative for would be to have a flat milled on the steering column shaft.
just use a grinder to make your stock shaft a "DD" Works great..
Thanks for all your help guys, I think I will make my shaft a DD and get the
1" DD x 3/4" DD flaming river joint #FR-1717DD.
Thanks for the look up of the Flaming River slip shaft, but the Borgeson is only $62.69. So I think I will go with it.
Jeremy
Hi All:
Jeeze! $269.00 for a steering shaft?!? I think I had $350.00 *total* in my Saginaw PS conversion!
If you are interested I can e-mail you a list of the Spicer u-joints and slip yokes I used to fab-up a collasping steering shaft. "PM" me your e-mail addy.
Regards,
Alan
Seattle
Regards,
Alan
Seattle[/QUOTE]
Alan,pardon the butt-in but, I am in the process of putting an "89" S-15 Jimmy column in my 40 and have been wishing for a way to set up a collapsible shaft between the column and the sag box. I am interested in any info you have. New enough here that I haven't figured out the pm thing yet though so here is my e-mail-- termitedon at dswebnet dot com --. I appreciate any info you may be able to send,thanks.
