Anyone use Schluter membrane and heating system for bathrooms?
Between pixels
I'm in the process of renovating two of our bathrooms, and came across this company. Looks well engineered, but pricey. They are selling a block of foam for a shower curb for CAN$67.00 which is insane. I want to add electric floor heat for the shower as well. A "complete" system looks like it will cost in excess of CAN$1000.00 for a 60 sq ft area.
schluter.ca | Homepage
I used the Schluter shower system in my walk-in shower. What's on the video is pretty much what I did. At Lowe's they're $480 or so.
Not having poured a shower floor before, I was concerned that I wasn't going to get the slope, thickness, and finish to get a good surface for laying tile. I did that shower about five years ago and I installed a new tub and tile surround in my other bathroom last year, but didn't use the Schluter. The waterproofing for a tub is much different than in the shower.
If I had to do it again, I would use it. Pretty simple really.
Yes. This product was awesome. I used the shower pan foam and Kerdi for the shower. I put up matte white glass tile so my drying process was longer than normal.
For my threshold I put a 2 degree slope in because of the shower door. The area was ( sold the house) 3'X2.5' so i didn't want water coming over the threshold and getting the floor wet. The house has a crawl space.
I put in a heated floor for the bathroom space but not for the shower.
Interestingly enough I'm remodeling my mom's bathroom for her now and I'm putting in a concrete shower pan. Given the job again I'd do Schluter anyday. They have a great system.
Thanks. Very nice. We're going to go ahead with the Keri-Schluter system (heating coil, thermostat, uncoupling floor mat, shower base and membrane). Wanted to install one of their longitudinal type drains, but that was another $700!
Radiant Electric In-Floor Heating Systems | WarmlyYours
Great customer service when you encounter issues.
Tried many other on different jobs and for me they are the best !
LOL. I must have their system in our front entrance because we have the same thermostat as they offer. I was hoping to use the same in our bathroom as I really didn't like the look of the one offered by Schluter. Now I will have to find out if it compatible. Thanks for the link. Are you Croatian?
My father was Croatian. He has a sister who moved to Buenos Aires. Never met her or her family though.
For the bathroom floor I used a product from Emerson called Warmtiles. Two things that I didn't like about it was the placement strips for the wires and the height up for the sub-straight. The strips were thin gauge steel. I think i remember cutting my finger on it and I was worried about cutting the plastic sheathing at the 180. The other thing I didn't like was they called for 3/4 of an inch from the sub-straight to the top of the tile. I achieved this by putting mortar down on the wires then hardiback then mortar again for the tile.
Thanks for sharing the link. Seems like a better system than what I did.
If you’re a pro doing this sort of work day in and day out, you can probably do other methods cheaper. But I have to say that it is a great integrated system that will provide a quality, professional result even if your skills aren’t absolutely top level. I spec them a lot because there aren’t a lot of professionals I absolutely trust.
Progress has been slow as my back gave out three weeks ago. Had to reroute the shower drain and supply for vanity and shower.
Have had nothing but problems trying to get the 3/4" NPT fittings to seal of
on the Hans Grohe shower valve. Must have had the damn thing apart half a dozen times. Used Sharkbite O-Ring fittings on the hot and cold ports which worked great as you are not supposed to do any soldering within 4" of valve. Switched over to a different type of teflon rape and it seems finally things are sealed. Had one solder joint let go at 1:30 in the morning after not leaking for 6-7 hrs.
