ditto bumpHello all, just wondering if there have been any updates on the video tutorials here. This thread is definitely heading into a direction I was hoping it would. I understand, if not. Thanks!
ditto bump
Bumping @Eric Sarjeant . I have. 2015 200 and I’m just trying to install my own illuminated scuff plates that would come same time as the courtesy puddle lights. Can I tap into the wires on the driver side by the brake pedal, as one poster previously mentioned, or do I need to go all the way to the fuse box (number 54 I believe) in the engine Bay.Bumpity... I actually installed the rock lights already. I just need to figure out how to wire them up to the dome circuit.
Yeah, pre-2016 you should be able to go under the dash light circuit on the drivers side. Recommend using a relay.Bumping @Eric Sarjeant . I have. 2015 200 and I’m just trying to install my own illuminated scuff plates that would come same time as the courtesy puddle lights. Can I tap into the wires on the driver side by the brake pedal, as one poster previously mentioned, or do I need to go all the way to the fuse box (number 54 I believe) in the engine Bay.
@prharper I have a 2015… which color was your wire that you spliced into? Or was it a fuse tap?Just wanted to provide an update. I spent some time going back and forth with SwitchPro support. Very responsive and impressed. We tried a number of options to get their pink trigger wire working with the illuminated door scuff plate. That light must be fully controlled by BCM. Reached out to @Eric Sarjeant who came to the rescue. He confirmed with his installers that they use the light on the lower driver side panel above the brake pedal. That worked perfect. Many Thanks Eric. I installed two LED lights in the engine bay which now get triggered when opening doors. I'll add rock lights when I install sliders.
Thanks Eric. I’m currently working at Purdue… I’ll have to stop by next time I drive over from the east coast.Yeah, pre-2016 you should be able to go under the dash light circuit on the drivers side. Recommend using a relay.
It was the blue wire that I spliced into.@prharper I have a 2015… which color was your wire that you spliced into? Or was it a fuse tap?
These draw such low amperage that seems fine.It was the blue wire that I spliced into.
Which circuit to tap into for 2016+? And how would it be wired up with the digital relay you mentioned?Yeah, pre-2016 you should be able to go under the dash light circuit on the drivers side. Recommend using a relay.
Did you ever figure this out? I have a 2020 tapped into the blue wire and my lights are on if the ignition is on, regardless. Sounds like it needs to be tapped into something else.Which circuit to tap into for 2016+? And how would it be wired up with the digital relay you mentioned?
Ideally would want the rock lights to come on when unlock at night (assuming dome light on door setting is the best way to do this?), and then also have a secondary OEM style switch on the dash to manually trigger it on/off independent of the dome light.
Haven't undertaken this, as I'm still not clear on what to do to make the rock lights come on together with key fob unlock on a 2016+ at night (along with the courtesy lights).Did you ever figure this out? I have a 2020 tapped into the blue wire and my lights are on if the ignition is on, regardless. Sounds like it needs to be tapped into something else.
