Anyone seen this before??
love2fly
Flying the Mountains of the NW
Have a stock 2F intake manifold PN 17111-61010 that we were going to use on a spare engine. We were getting ready to blast it for clean up and noticed the carb mount base has an angle to it. I can't tell if it been milled down by PO for some reason. Looks to be stock cast. All of the other area's look to be as they should, no tweaks, no bends or cracks.
I guess the carb will sit at a slight angle when installed unless we can mill it flat.
Any input before we carry on?
The intake on my 71 F engine has the same angle (as near as I can tell). I just figured it was since the engine sits with the rear sloped down a few degrees. That way the carb stays level. :meh:
:cheers:
I was curious, so I just stuck my angle finder on both my engine and spare intake manifold. The engine sits at a 3* slope to the rear. Mind you, that is with a 4" lift, aftermarket shackles, and 41 year old motor mounts. My spare intake manifold slopes approximately 2* towards the front. So, that pretty much makes the carb sit level on level ground. There you have it.
:cheers:
slope mount
Interesting. I have two other manifolds one a old F model, and the other a 1982
2F manifold and they are flat like my high school girl friend.
I two first was thinking that it is due to engine angle but.......not to sure, the angle is kind of lower in one inside corner. Its like a chair with one of the four led shorter.
The bolts for the exhaust manifold go in fine so I guess its not a big deal, just different.
:meh:
the engine is lower in the rear so oil flows back to the pump common on most cars and trucks .manifolds are machined to keep the carb level, now you will notice this on any carbed engine you look at.
Never seen that before. Maybe they are not for Cruiser? Perhaps a stationary application? :meh:
carb base
Well I guess one can speculate on this for some time. Not saying anyone's opinion it wrong just not sure. I guess you have to have it in your hands to get the real feel of what it looks like. Looked at the base again with a magnifier and it's not been milled other than the factory, so you got me. Is a stock manifold with all the Toyota stamps and numbers. I may put the 82 manifold on and set this aside and mill it flat later. Just weired. :confused:
Jim, I;m bad, went out to the shop to the loft and take another look and the newer one is a 17111-61021, but its flat. No angle? Will have to look at the other as its at the house were the engine is on a stand. I know that's its flat also?
I will check the degrees later on this one.
:cheers:
