Build Anyone recognize this 80
Good progress today on mounting the Puma compressor, but it did take a lot of bolting/unbolting, manipulating, dry fitting etc. I started this over a month ago when I acquired the compressor. Between then and now I've spent more $$ than needed and now have a small stash of parts that I may never use. I've learned something about pipe fittings and compression fittings. I've learned that I cannot smoothly bend 1/4" copper tubing. McMaster Carr is quick with orders even when what I ordered is wrong.
The short copper line in the photos plumbed back to the pressure switch is what came from the factory. I was able to reuse this by cutting a section off and slightly bending.
To mount the compressor under the 4X4 labs basket and fit it into the quarter panel I had to unbolt the compressor head and reroute the copper tubing. At first I was going to leave this off and go straight with a rubber line but decided to keep the copper line. The switch box with the cut off valve then mounts to the copper line. I do not want the switch box floating free and potentially leading to fatigue in the copper line so I bolted a piece of sheet metal to the side panel using an empty hole. A 6 mm nutcert was used in the hole. Then through this panel I drilled another hole through which an extension of fittings will go. This should support switch box. I'm not done with this and will look for some insulation to aid with the support.
Short airline will then run from the switch box plumbing to the regulator and airline quick release. I think this will work. Next up is wiring and I'm 6 ga back to the battery, along with Anderson connectors at the compressor.
View attachment 4162556View attachment 4162557View attachment 4162558View attachment 4162559View attachment 4162560View attachment 4162561View attachment 4162562View attachment 4162563
That set up is looking good. Happy Sunday to you and yours.
Puma air compressor is mounted, plumbed, and wired and works, but I want to tweak the plumbing because I think I have a leak. I'm using 6 ga wire, a 50 amp fuse, and Anderson connectors for the wiring. Compressor is obnoxiously loud when running and vibrates against the 4x4 Labs basket. The switch seems a little light, i.e. could accidentally kick on, so I'm keeping the positive wire disconnected until needed.
Also installed a new OME steering stabilizer.
A bunch of electrical and fuel related spare parts that fit within a couple of small boxes. The boxes take up little room so will stay in the 80 full-time except when transferred to the other 80 when we take it on long trips.
Spring swap on the 1997 Land Cruiser. We've had this one for 20+ years and it's gone from stock suspension, to OME stockish lift, to Iron Man mild lift, and now back to stock. My wife mainly drives it and she has knee problems so I decided to lower it Cruiser. We'll also be going back to stock wheels and 265/75/16 tires instead of the 285s currently on it.
4 new OEM springs and each had a different part number, got the numbers from @OGBeno.
48131-6A570, I put this on front right
48131-6A480, I put this on front left
48231-6A680, I put this on right rear
48231-6A690, I put this on left rear
Plus a couple of new rear spring rubber cushions 48257-60020
Pre-lift with Iron Man
Iron Man with rear spacers, should have left those off.
New front OEM spring.
Back to stock height.
