Anybody use Dyna Beads?
West of the Pecos
Anybody use Dyna Beads to balance your tires?
If so, long term likes/dislikes? I heard a rumor that they could break down into a powder after a while and then not work at all. Any truth to this?
thanks.
Yes
Dyna Beads smoothed out my 285/75/16 trxus mt's quite nicely I can go above 55 since i put them in.
as far as long term I dont know yet I have had them in for about 4 thousand miles. it took like two weeks to get here (NY to AZ)but well worth the money and I will buy them again HTH
I run dyna beads in my 36x13.50 and they work well. Just keep in mind that these beads work only for static balance, wider tires will suffer from more lateral inbalance which in your case is very low. I got mine directly from the company with usps priority in just a few days.
BTW, dyna beads will never break down into a powder.
The new tires I'm looking at are roughly 33.5x10, so not "wide" by any stretch.
FYI: Somebody told me Revos have "grooves" inside, so the Dyna Beads didn't work for them.
Do any of you run with NO weights at all, or do you use Dyna Beads in addition to normal balancing?
Do you just dump them into the tire during mounting? Then there is no need to balance with weights? Will most tire shops put them in for you? Obviously I don't know much about these things, but I've heard they work well. Thanks.
Edit: Great minds.....
Have you thought about centramatic continuous wheel balancers. I haven't used them myself, but have heard good things about em.
Onboard Tire & Wheel Balance Systems, Tire Rotation, Tire Balance, Tire Balancing - Centramatic
Centramatic's Continuous Wheel Balancers - - Toyota at Off-Road.com
I don't see how they would work any better than dyna beads. They cannot solve lateral inbalance, and their web site does not address the question.
I'm not sure if interior design of the tire could prevent dyna beads from working. Send them an email and ask.
Do you just dump them into the tire during mounting? Yes. They sell a break open bag. You just stick it in your tire before mounting tire to rim. Then there is no need to balance with weights? Nope Will most tire shops put them in for you? Yes. This should not be a problem. Obviously I don't know much about these things, but I've heard they work well. Thanks.
I have these in my 37's and they work great. I have no weights.
The centramatic discs can't work as well since they can only balance to whatever diameter the disc is. The closer you add weight toward the edges of the tire the better the balance. A 20" rim with a 35" tire will balance better than a 16" wheel with 35" tire since the weights on the wheel will be closer to the tread on the tire. (Less sidewall). The Dynabeads go farther out from the center of the wheel since they can travel to the farthest most point inside your tire. I think of it as the Dynabeads have more leverage. Does this make sense?
You can do it either way.
I'm waiting to see Bear80's response on this. It seems like a valid arguement.
I run their product in my 36" Swamper TSX's with great results. IIRC each tire has ~10 oz. and runs nearly as smooth as any radial MT I've ever had balanced with lead.
I also ran 6 or 8 oz. in my last set of 285 MTs for 30k of the 40k that was on them and I attribute the awesome wear to constant balancing. They had 80% of the tread left when I removed them.
I have no affiliation but they sell a good product, offer good customer service and with little work is completely reusable.
i have dynabeads in my wheels. THey work OK, but above 65mph i get a wobble.
This sounds like a lateral balance problem or something else. There just isn't any possible way that the beads cannnot balance above a certian speed. Usally though a lateral inbalance will be felt through any speeds but noticeable at higher speeds.
If I recall correctly a wide tire is anything above a 245mm. So there is a greater chance the typical 285/305/315 size most run here will have some vibs even with dyna beads. Tire brand and tread style also makes a differnce in how much lateral inbalance the tire will have.
I think you are right. Or, i think i may have a panhard bushing worn (i have never replaced :eek:). Even at low speeds (35-50 mph) i get an occasional wobble. Wheel bearings are tight.
BTW, i'm running 315 nitto terra grapplers.
Does the dynabeads stick to the inside of the tire like the Counteract beads do?
Counteract uses static electricity to keep the beads were they are needed even after you stop.
Equal is a power that falls to the bottom of the tire when you stop.
I tried both and got rid of the Equal as I got sick of the tires shacking every time I stopped.
Does dynabeads need to be rebalanced after every stop?
Anyone look inside the tire after you removed the tire from the rim? Where was the beads?
dyan beads are just that BEADS. Not trying to be rude but a read on their site will fill you in all the details. The beads are made of ceramic and will not break down, and they constantly roll into the light areas of the tires to keep them balanced. At every stop the beads roll to the bottom of the tire. As ibcrusn posted, the beads can be reused over and over.
I'm very happy with the dyna beads, however I also spent the extra $$ to have the tires and wheels ride matched before I put the beads in. I would say with a top brand tire the need to ride match is lower but with my swampers it was well worth it.
