- Thread starter
- #21
A couple more. The last picture is of the electric vacuum pump.
GG
GG
well awesome! I see your playing with the thread edit features
The wires to the field and push button should also be fused. Otherwise when the field shorts later down the road and you draw more amps to ground you suffer the chance of a wire melt down or smoking dash syndrome.
Did you remove the resistor?
What is the vacuum pump from? Also lets see your alternator....
Cool !
which model did you buy? it lists 2.
I have not farted around with my resistor, so this is speculation.... But I'm pretty sure when you look at you melted pic in the first post that the resistor goes into the intake manifold. To by pass the resistor I would just bolt the busbar leads down together in that spot. which out isolators that feed you thru it. My guess is the resistor is completely shot and you get full voltage thru it.,
also not sure if you have done this, but open the side kick panel on the LH side to disconnect the glowplug timer. otherwise it will keep all the circuits live even though the relay wires are cut.
The '55, which has an '81 BJ60 harness in it (non-SuperGlow), runs the glow wire directly to the plug on #4 cylinder, there is none of the other stuff there, no resistor, no isolators, nothing. I can take a picture if you want.
If I were doing this Wilson switch thing that's what I would do!
If you're pulling out glow relays don't toss them! I may be interested when the FJ45LV is far enough along. I'll be in Surrey next summer again. I even hope to make "Cruiser Days" in 2008!
If you saw my shop you'd know I don't throw out anything... drives my wife crazy.
GG
