And why it's melting.
GG
GG
Can't answer your question but if it is afterglow your looking for I have some brown habeneros which I picked up in Cawston which give a real good afterglow.![]()
the wilson switch uses the stock wires and relay, but cuts out the timer and the afterglow. If your primary relay is working fine I would do the wilson trick.
search under greg's name in the diesel section for a description.
10.5 ngk plugs are listed in the parts thread. They are not too expensive.
You will be happy how nice she will start with fresh 10.5 plugs and a push button.
Oh on that note, try to only use a push button to activate them, a switch can be forgotten.
mmmm... habeneros... makes me mouth waterGG
Thanks Brownbear, I did search and got the info, MO switch (momentary on). I gathered from the thread that the idea was to use existing wiring and relay. Somehow I would find more securiy in hooking up a 100A solenoid and switch. I'm guessing I wouldn't need to glow the plugs to long, :whoops: depending on the ambient temp.
GG
If you don't care about any of the wiring or the cute little light that will tell you that you are pressing a button - scrap all of it and just run directly to the big relay, I picked up the NGK plugs (10.5V) at under $15.00 each. Next mod is getting rid of the EDIC and using a mechanical control - too much electric crap in there.
I would not lose the edic if it is working properly.
Too many variables of screwing it up with out the edic.
For example, rigging the arm properly, too much fuel in the over inject direction is bad. No overinjection for starting, no low oil px protection. Maybe more.
Ya, just dreamin' of losing the edic, don't think it will be happening soon. I wish I could get rid of the relay though, that's what I have trouble with.
Granite you need to replace your fuel injector lines before the rot thru. Damm that's rusty.
You should see the rest of the truck!!
If the ends are still good make your own out of line. Use the ends. napa sells a double flare too for cheap.
