Any way to stop dashboard beeping if trunk window is open?
California
I was bringing some lumber home in the GX, and the haul would only fit by having it extend out through the trunk window. I realized early on that it would be a LONG drive home because the dashboard beeped whenever the vehicle was in motion because the trunk window was open. Knowing Toyota, I assume there is no way to disable this alert that I am an idiot for trying to drive with the window open, but I thought I would ask the gurus here anyway. Is there a way to stop the dashboard's audible warning if I want to drive with the trunk window open?
Just engage the latch with a screwdriver and remember to open window latch before shutting window when done.
Kind of like when you have the door open with the key on, and it keeps beeping, I just use something to push the "button" in to make it think the door is shut!
I believe that's what Acrad is referring to, correct?
It may be some little widget you make and want to keep in your center console for whenever to have to drive with the back window open.
Thanks for the suggestions. I'll find a way to engage the switch next time. Seems like a simple enough solution.
