Any US drawers like this?
Idaho
I’m searching for the perfect setup. I found these drawers but it appears that they are only made in AU. I know trex box makes something similar but I don’t like the rigidity of trex Box and I like the idea of the slide with smaller drawers. I optimal want the shelf extension along with 2 smaller drawers above it as shown in the last couple of pics. Any options or mfgs that do this? I wonder if the reef system could dab something up? Thoughts?
You can get custom drawers from Drifta via their US distributor Drifta, MSA, Ark, Maxtrax, Quick Pitch and Max Coupler overland gear!. A few folks have looked into this option but I'm not aware of anyone who has pulled the trigger.
Re: Trekboxx, they do take on custom projects from time to time if that's something you'd consider? Otherwise, you're probably looking at modifying the Reef drawers or building your own from scratch (which can be a fun project for sure!). Search for the drawer system that @619TOY made.
Have you looked at ARB? They have different height drawers that can be stacked(pretty sure on the stacking). And there are plenty of US distributers.
Ive looked at all the major brands and trex is the only one to offer that pull out table. Im trying to get my "perfect" kitchen set up and the extended work station would be optimal. I haven't ruled out making a custom setup but wanted to investigate if there were any other easier options.
For anyone who is interested... I wanted to add a 'kitchen box' to my drawer system that I could grab and go when I am headed off for a quick get away. I originally had the KISS drawers for my 100 series, and went with ARB for my 200 series - and this box works perfectly for both. I started by buying a Decked tool box thinking it would fit. However, it was about .5" too tall for my KISS drawers. So I modified it by replacing the top with a cutting board surface and using latches to keep it in place. As an added bonus, the top fits perfectly across my ARB drawers with the latch tabs holding it in place to make a cooking / cutting / drink mixing surface. And of course, the entire thing fits perfectly in the ARB and prior KISS drawers. Pictures do a much better job of explaining.
@erikvogel looks good. I did similar back in the day when I had ARB drawers. I used some Richlite on the box top and then could remove and turn it for use on top of my drawer. In my case neodymium magnets to hold it.
@Desmothedog Cole is correct about TrekBoxx - they can and do custom designs. My 100 has an additional shallow drawer for instance. My 200 has a standard Alpha layout.
