looking at it last night I think I could at least get the trany mount pretty easily. I would break the two lower bolts free then break all the cross member bolts free. I think I could support the transfer case with a block of wood and the jack. Then just drop the cross member. I would not really be "lifting" the drive tran just "supporting" it. I know the forces are basically the same between lifting and supporting. Except that when you start lifting you run the chance of something binding and then increasing the load on your lifting point very quickly while you are jacking. Also if you think about it, if you have the drivetrain load spread over 3 motor mounts evenly, lifting by one of then makes a disproportionate load in that one area. I look at it like this. If I loosened all three mounts and than jacked up just the front left enough to change that mount, say 2 inches. I bet the other two mounts would be twisted or slightly raised as well. so the load is increased in some areas more than when it is all static. But think dropping the rear cross member and supporting the transfer case should basically leave everything in its "normal" position. Hope that makes sense.
