You guys go a little further on this and we'll end up seeing the whole thread go *poof*.
Wrench said:I'm concerned only with off road. Does going to 37's over 35's make a really big difference on the trail? Or is it marginal?
Junk said:You guys go a little further on this and we'll end up seeing the whole thread go *poof*.
bjowett said:An inch is just an inch
sleeoffroad said:Yes, it get's your rear control arms mounts 1" higher. Then with the MAF brackets they will only be 3" lower, but with a 6" lift they will be 3" higher than stock, but that is not compared to a stock truck, that is compared to a 4" lifted truck, but is you use 1.5" spacers and 4" springs it will be 2" lower than stock brackets, but still higher than a stock truck.
Walking Eagle said:I'm assuming this is a dig at me. It's not appreciated. I drew wrench a freak'n picture to explain what I ment by lower compared to what he ment by lower with no refrence point. If you don't get the point, that's not surprising.
Bottom line is, larger tires always help on the trail, if you can don't break, your steering does not conk out, youi don't bump stop the hell out of it and you have the balls to drive it.
PS, anyone got 44's for sale?
clownmidget said:Yeah, I figured that but was trying to be funny which isn't really working on this list lately...
Folks are wound up a bit about them brackets and their lifts and all.
You gonna go to coilovers with the 44's? Did you check Super70's rig in the hardcore section?
