Any LED brighter better than pfran
musthave
All maps, one app!
Supporting Vendor
Florida / Colorado
I have Pfran lights in my first cruiser, and I am considering getting them in my second. Is there a better / brighter LED available for map light vanity light etc.?
PFran's blind me. I never wanted any brighter of a light, especially the front map light. As to the original question, I am not sure if there are any better or brighter lights.
I have the PFran's lights throughout and am very pleased, but the map light seems especially bright. I have no experience with any other lights (other than reading about higher priced options on MUD). I had to re-do the 3m tape in the map light to get it to stay in place...but other than that, I don't think you can beat the price. Before PFran's lights...I needed a flashlight to see the floor/console the FZJ with the map light on, they were so dim. :(
5050 48SMD Car LED White Interior Dome Reading Light Panel Bulb
You'll have to make your own way to connect it but it fits perfectly in the lens. The 48 led versions are beyond bright, there is also 24, 18, 15, 12 and 9 led versions if you want to try a dimmer set. The 5050 smd are the ones you want, true white bright light.
BTW, Pfran is charging a killing for a made in China product. I've bought tons of stuff from banggood.com.
I also made my own set of reverse bulbs that are double the brightness of any "cree" led bulb. I don't have a set of Pfran reverse bulbs to compare directly but from the research I've done I believe his to be the same type you can buy for less than $10. There is one typical 300mA driver that can fit inside the bulb, no 900mA or higher driver can fit in the bulb.
