getting mixed info on the wider net...figured I'd come to the hive mind here. anyone ever break something on their 80 using bug cleaner and a pressure washer?
^^^^^I might be able to come up with a faster way to flatten all the fins over on the radiator, but I'd have to think about it some.
I mean ya don't gotta stand right on top of the radiator with it definitely don't use a spinning tip or the straight line stream and yes you can bend the fins over but if you go after it from far away and work to it and depending on the power washer.^^^^^
TWO pressure washers.....otherwise you are right. No faster way to flatten all the fins.![]()
