Front dive (off road, dropping down rocks and ledges) is well controlled with the OME N133 shock on the 100. As for braking? VERY little dive and thats with my accessorized truck.
ShottsUZJ100 said:31mm is my diameter.
Aug:Augie said:I don't think you could use 32 mm bar from the diesel. They have shorter length because the
transmison cross member sit at slightly different location.
Jukelemon said:Aug:
The diesel T bars are longer not shorter.
shocker said:The question would be if the added length comes from longer spline areas or a longer neck.
As you said, as long as the splines themselves are the same, the petrol 100 series has enough additional room to accomodate a longer splines, but not a longer neck.
I'm pretty sure it is the splines, though, because a longer neck would necessitate the crossmemeber to be further back on a diesel, and I'm not sure why they would do that.
calamaridog said:Didn't need to know that!
SINCITY100 said:The only negative thing that I experienced with my OME shocks, t-bars,heavy rear springs, and slee diff drop is that I could kick myself in the a#$ for not installing this kit sooner !!
I read about the huge improvements in ride, cornering, stability, etc.....But thought, "come on, how much of a difference could it actually make......OMG !!
My 100 changed overnight into a true "sport" utility !!
As far as comments about the OME shocks (some dont care for them too much)..I am VERY pleased with the ride and the incredible job they do in handling high speed runs over uneven surfaces...I can`t imagine seeing much improvement over the OME shocks, but I have said this before.....![]()
Bad azz Cruiser said:well based on the info looks like you just can't go wrong! I'll be building my cruiser in the next coouple of weeks!
Hey Shotts, what size tires you running?
Landpimp said:
ShottsUZJ100 said:I think I get this? You were a non-believer but now you are a believer? Did I get the meaning behind the![]()
