any companies out there making custom weatherstripping?
installing sample weatherstrip
No I beleive it is diff but what I am really in need of is the inside track/ felt weatherstripping for the sliding windows. My outside rubber W/S is diff as well for it has holes at bottom for water to drain out from water that gets inside the window track.
R
View attachment 342596View attachment 342597
Reviving old thread. I just released a new reproduction of the sliding window inner weatherstripping. OEM part # 62761-90300. It fits the sliding windows on both the FJ40 LX as well as the Troopy. Link to the store page.
Hi - shoudn't the oem part number be 62753-90300 (left hand side) and 62754-90300 (right hand side)
instead of 62761-90300 ? 62761-90300 is the oem number for the weatherstrip. I believe your
reproduction part is the "run" in the diagram. If you have the side window weatherstrip, I'd be interested in getting two
of them.
of them.
No, what I have is indeed the weatherstrip, not the run. The run is handed, the weatherstrip is not. Those two part numbers you gave are for the run. See photo below:
Hi there, do you already reproduce the Run, the part inside the alu frame? Cheers, Luc
Yes. Everything is available:
I have some weatherstripping off my 83 BJ42 LX that is no longer made for slide sliding windows and needs to be replaced, any one know of any companies that can make weatherstripping if they have an original piece?
Thanks
R
Roberto, I'm not sure if you are still looking for the weather striping or not, but here is a link to a company that makes 1000's and will do custom for you as well. www.cooperstandard-isg.com
