Anti-Inversion shackles
  • Thread starter Thread starter Hodag
  • Start date Start date
H
Hodag
Guest
Does anyone out there have a set of the triangular shaped anti-inversion shackles? Would you be will ing to snap a couple of pics and take a couple measurements for me. I have the materials and equipment to build my own, just need a pattern to use. Thanks, Hodag
from Man-a-fre, 4+ brand
I just took a few pics of mine, I've been told they're Man A Fre 4+. In the picture I'm holding a tape measure in what seemed to be strategic places. Unfortunately I'm too stupid to to post pictures to this board. If you want, PM me with your email, and I'll send them to you right away.
-Matt
Why do you think you need these?
I put these on my wagon and now consider them "snake oil." However, they would be the easiest to make at home.
I guess I dont know f I need them or not. I guess I could just as easy copy my ConFerrs. Whats the drawback of the anti-inversion shackle? Im gonna build something for my 40. I will be doing a springover, shackle reversal, and PS. Thanks for any help. Hodag
I have them on my 40. From SOR.
There is no drawback.
They are recommended by some on trucks with lift springs. There have been some reports of skyjackers inverting, which is not good.
They were not much more than greasables, so I figured what the hell and got a set.
Let me know if you still need measurements.
OK, figured out picture posting (Thanks Mike).
Here's a couple pics of the anti-inversion shackles, complete with strategically placed tape measure. Let me know if you want any more.
-Matt
Well the stock 40 shackles are 2 3/4" pin to pin. What you need after that is up to you. For example, a 3" extended shackle (5 3/4" pin to pin) will give you an extra 1.5" of lift. Did you also need the measurements to the extra pin? I am pretty sure you will not be able to duplicate ours however. We cut a groove the full length of the pin to distribute grease evenly. We also use a larger size pin than the threads on the side. Because the center of the pin is larger, and actually threads into the side plates, it is impossible to overtighten. Not like con-ferr and other competitors which have the leverage bar in the middle so your gauranteed to bend the plates and crimp your bushings. We also re-heat the pins after they are cut to get back the strength and cadium plate everything so it will never rust. :D I have seen quite a few inverted springs come in, its not something you see all the time, but something that really sucks if it happens to you. Steve.
I have never seen a spring fold backward. I ran them for a while (with 4" Skyjackers) and decided to run something different. If you don't plan on wheeling the crap out of it then I don't see the need. My .02.
Later,
