- Thread starter
- #21
Abetrader,
Check post #3 above...I haven't replaced the mast on my '97 FZJ80 yet (I'm slow at fixin stuff) but AFAIK you have to remove the motor from the fender well to replace the mast/cable.
The mast/cable that I ordered from CDan didn't come with any instructions for replacement so I wouldn't expect any.
I have heard that the later year 80's are more difficult to work on when it comes to the antenna motor/cable. I can't remember exactly what it is that changed or what the cut off is year wise but basically what I was told is that you can only get the motor out so far from the fender well so basically you have to work on it right there. IIRC the early model years you could take the motor completely out. Maybe the antenna lead itself was removable or something, don't recall.
In that post he is referring to the cable that has a tooth chain that the motor retracts and extracts. My 94 does not have any teeth on the cable it is smooth. When I went to the dealer to buy a replacement cable I was told that my antenna cable was connected to the motor and I had to replace the entire motor to replace the my broken cable. I think that the antenna radio cable also is attached to the motor too.
My chilton's manual just says to just remove the antenna nut, and you can pull the mast and antenna out, and feed the new one in, put the nut back on, and that's it. I don't know how helpful this manual is going to be. Would it be in the FSM?
I did check the FSM and wasn't able to find any detailed info on the cable. I think what the Chilton manual is referring to is the antenna cable that has teeth on it.
