Antenna - Repair or Replace
S. Jersey - New Germany
I'm looking for some opinions on what to do with my antenna. The antenna is fully extended in this pic.
What I need to know is if it is worth the time and effort to repair this and how or replace it with either a stock one or an after-market one. If I replace it what is a good after-market replacement antenna for the 94 LC?
If the line were cut closer to the tip of the antenna, I'd say repair. You've lost a lot of line there though.
The test would be to get the end of the line up through the mounting hole and see if there would be enough left to fully extend the antenna.
Collapse the antenna down and there should be a knurled metal bit on the end of the nylon line. It's actually a nut that goes onto a threaded bit inside the metal antenna.
I had one of these that was chopped off fairly close to the knurled nut and was able to patch it all together using a filed down core from a butt end connector (electrical bit). I crimped it to the nylon and the threaded bit. It has been working fine for going on 4 years.
I'm not sure if yours will have enough line left though. It appears to be cut pretty close to the spool.
IIRC the line itself is only available if you buy the whole spool & motor assembly. The metal antenna is available by itself, but that isn't going to do what I see in that picture much good.
I went throught the same decision. Check the FAQ as there is a write up. The antenna that is attached to the plastic cables is reasonably priced from Toyota. It's a few bolts and then you can get the moter out of the fender. Open the motor, get out the plastic piece that left inside and replace. Pretty simple and straight forward. It's a little rough if you have large hands though because the hole is small. Here is John Davies write up that I followed. Worked like a charm.
http://www.spokanister.net/vehicles_antenna.htm
Actually I'm pretty sure the antenna comes with the line as opposed to the motor. At least the one I have at home from Cdan came that way. Wasn't all that expensive either IIRC, especially if it gets the :princess: to stop complaining about it :D.
Just replace with oe mast and cable. Worst case to remove the motor, clear the old cable, reinstall the mast and cable: 1.5hrs. However make sure you have a couple of replcement clips which holds the wheel well liner, you may need them.
Not that hard of a project.
Good luck!
I stand corrected. Apparently the line comes with the mast. If so, get that.
Pulling that motor assembly is a PITA. Stringing the new FM cable back into the dash is worse. Avoid it if you can.
X2 I don't recomend replacing motor and wire to the radio unless you need to have you AC charged. You have to pull out the AC evap to get back there to rout the wire as it comes from the factory.
Thanks guys, I read the repair procedure http://www.spokanister.net/vehicles_antenna.htm and it looks very doable. Thanks BPMOU for the link.
The only thing I need to get is the mast cable. I replace the antenna mast only a week before the the cable broke so that is new. When I bent and broke the old mast is probably when I damaged the cable which is why it broke soon after I replaced the mast.
I saw on cruiserparts.net they have the plastic wire for around 50$. Its brand new.
Oh and to route the new fm wire easily cut the old one from the old mast, then attatch the new fm wire to it and pull it through. The new one will route where the old one was.
Check with Cdan...I'm pretty sure the mast with plastic cable brand new was like $30-$40 :). Got to feed the dogs you know
When I bought the mast that was around $30 from the dealer. I wouldn't mind going through cdan but for something small like this I rather use that favor for something more important.
The dealer is only 3 miles from my house.
Never sweat the small stuff:beer:
So true, but NEVER let the Parts Shaman see that :)
I grouped my mast purchase in with a bunch of other stuff so it didn't even make a blip on the cost radar :eek:
I still would fell funny ordering just a antenna cable.
Before you buy a new mast, I would pull the old one out first to see what type it is.
My 94 antenna was not the geared type like my other toyota's.
The end was clamped to the motor and the nylon cable was smooth. (no teeth).
I wasn't a MUD member back (4 yrs ago) then so I couldn't ask a help question.
I went to the local dealer and was told I needed a whole motor with antenna. I think I paid a little over $100.00.
Good luck
+1 on that. I've replaced the mast on both 93/94 and 95-97. I don't think the newer style is compatible with the old style. The cable is completely different on the new style and comes attached to the new mast. EricG has a good motor/cable off a 93 he might sell you if you want to PM an offer to him. All you'd have to do is install it with your new mast and you're good. :)
Good luck
Mine doesn't have any teeth. Thanks for bringing that up. I was already to jump into it.
I've replaced the mast twice and both times it was sold by itself. My mast screws on to the cable. So I guess this means that I will have to buy the motor too?
I was hoping someone would respond to my last post so I'll try again.
It seems that I have a mast cable without any teeth, you know the smooth one. Is there anyway to repair this or will I need to replace the whole motor too?:confused:
So let me get this straight. I have a 95 cruiser, my motor is working fine, but the mast will not fully extend or retract, just move up and down about 15 inches in between or so, so I know the motor is fine.
I was looking at the linked thread, but found if confusing if I'm just replacing the mast without removing the motor.
My question is how do I remove the old mast/cable, and then do I just feed the new one in until it grabs and continue spooling it down until the mast is fully retracted?
Sorry for the noob question, but I'm in no way mechanically inclined at all, but I don't feel like paying the dealer $100/hr to do it for me.
Any help would be greatly appreciated. Also, if I order the mast through Cdan, does anyone know if it comes with instructions?
Abetrader,
Check post #3 above...I haven't replaced the mast on my '97 FZJ80 yet (I'm slow at fixin stuff) but AFAIK you have to remove the motor from the fender well to replace the mast/cable.
The mast/cable that I ordered from CDan didn't come with any instructions for replacement so I wouldn't expect any.
I have heard that the later year 80's are more difficult to work on when it comes to the antenna motor/cable. I can't remember exactly what it is that changed or what the cut off is year wise but basically what I was told is that you can only get the motor out so far from the fender well so basically you have to work on it right there. IIRC the early model years you could take the motor completely out. Maybe the antenna lead itself was removable or something, don't recall.
My chilton's manual just says to just remove the antenna nut, and you can pull the mast and antenna out, and feed the new one in, put the nut back on, and that's it. I don't know how helpful this manual is going to be. Would it be in the FSM?
