Ok guys, I know this is a little bit of a dumb question but I searched and couldn't find what I was looking for. Didn't find it in the FSM either. I am trying to replace the antenna since the plastic retractor broke. I have a new one from Cdan and can't get the old antenna off. There was a lot of corrosion at the base of the antenna. Anyone have pictures or explanation or reference in FSM or anything so I can figure this out? I've been following the antenna replacement in the FAQ but this step isn't very clear.
You can see how much corrosion there is. I took off the plactic/rubber pieces that I could, but the one still showing in the first picture at the base of the antenna is stuck on pretty good to the corrosion. I'm afraid that if I take it off it will destroy what's left of whatever the corroded metal piece is supposed to be.
Is there something in the antenna motor housing holding the antenna mast in that I have to unscrew?
Thanks.
Thanks.
