I finally decided to tackle my power antenna problem. Upon disassembling the mast I realized that there was no cord attached to run to the motor. The motor itself is plugged in, but does not appear to work when I push the buttons to raise or lower antenna. So, I'm operating under the assumption that the motor is dead and I need to remove it. My question is, how do I access the antenna running to the back of the radio without removing the fender? I have a replacement antenna motor and mast assembly from cruiser yard, but not being able to see how the cable is running into the cab makes me nervous. I've searched through dozens of threads and nobody seems to have talked about replacing the entire assembly, so I'm putting my fate in the hands of the experts. Does anybody have any insight as to the easiest way to tackle this job?
;p if you go with a different antenna...
