Antenna Assembly removal
Saint Petersburg, FL
Hey guys! Having a little bit of a hard time getting the antenna assembly out. Does anyone have a good video or step by step explanation for this ?
Just dive in and get after it. What are you doing? Mast perhaps?
You can't take the assembly out unless you remove the antenna cable through the firewall. It is probably sealed with pucky, and you will have to use a pull-string and lots of patience.
I was able to put in a new mast without removing the motor assembly. Yeah, it sucked, but nowhere near as bad as pulling the cable.
My only advice is to clip a towel in there as a work area. You'll drop stuff, and you'll be glad you had the towel there.
View attachment 2275329View attachment 2275334
Wow thank you so much man. I have a donor cruiser and need a new one in the 78k mile one Im restoring
