I have a 91 with the stock (recently rebuilt) 3FE.
I bought this from my girlfriend because she needed the money, and I trusted her when she said nothing was wrong. ...stupid.
Anyway. Here's what happens.
From the first day I drove it, it would not immediately start once I drove it for a while. This happened plenty often, so I would remove the battery cable, or pull the fuses to reset the ecu. I am now not sure that did anything at all. Sometimes it would start, sometimes not.
This went on a couple months and I just learned to leave it alone for a while (sometimes 10 minutes, sometimes an hour) before I tried to start it again.
Last week I was almost out of gas at a gas station, so I left it running while I fueled up. As I was pumping fuel in, the engine began to stumble. I thought....you know... made it just in time.
But I still did not have enough fuel in to get home and repeated this some 50 miles later, with the same result. I know I did not "just coast into the pump" twice.
Since then, she has failed to start. I have new cap, rotor, plugs, plug wires. I tried to pull codes Te1 to E1 right? ....no CEL flashing at all!
Good battery.
What was weird was how much pressure was in the tank when I opened the cap.
I got a good price on this truck, and would like to keep it.... but this sure is not what I had in mind when I bought a landcruiser.
Please help.... suggestions for now. I will try anything and everything this weekend.
I will answer all questions.... or accept reasonable offers for you to drive it home. Fresh engine and 91K on the chassis
Good battery.
